My Porter Cable pancake air compressor is getting too hot and melting my air hose
ASSUMING THIS IS AN ELECTRIC MOTOR DRIVEN SINGLE STAGE COMPRESSOR, IF THE COMPRESSOR USES OIL IN THE CRANKCASE, THE PRESSURE SWITCH SHOULD CUT OFF AT 125 PSI AS THE ACT OF COMPRESSION HEATS THE AIR QUITE HOT. THERE IS ALWAYS SOME OIL THAT PASSED THE PISTON RINGS IN THE COMPRESSED AIR. IF THE COMPRESSED AIR GETS HOT ENOUGH, THE OIL VAPOR CAN IGNITE AND THE FLAME CAN CARRY TO THE TANK FOR AN IMPRESSIVE EXPLOSION. THIS ORDINARILY DOES NOT HAPPEN BELOW 175PSI OR MORE.
OILLESS COMPRESSORS CAN BE SET TO 150 PSI. WITH EITHER TYPE OF COMPRESSOR, THE HOSE SHOULD BE ATTACHED TO THE REGULATOR OR THE REGULATOR STACK, NEVER TO THE COMPRESSOR, AS THE COMPRESSED AIR LOSES MUCH OF ITS HEAT WHILE IN THE RECEIVER. IF THE WHOLE TANK IS GETTING HOT ENOUGH TO MELT A PROPERLY ATTACHED HOSE, YOU HAVE A DANGEROUS SITUATION, CHECK THE OPERATION OF THE PRESSURE SWITCH, UNLOADER VALVE AND RELIEF VALVE. THE RELIEF VALVE SHOULD OPEN AT NO MORE THAN 150 PSI, THE UNLOADER VALVE OPENS WHEN THE PRESSURE SWITCH SHUTS THE MOTOR OFF, AND SHOULD ONLY HISS FOR A FEW SECONDS AS IT DUMPS THE PRESSURE ONLY IN THE COMPRESSOR AND THE LINE FROM THE COMPRESSOR TO THE TANK INLET CHECK VALVE. IF THE UNLOADER VALVE HISSES MORE THAN A FEW SECONDS, THE TANK INLET CHECK VALVE IS LEAKING AND NEEDS TO BE SERVICED, CLEANED OR REPLACED. IF THERE IS CARBON BUILD UP IN THE VALVE, THERE IS EXCESS OIL PASSING THE COMPRESSOR PISTON RINGS, REPLACING THEM MIGHT FIX THAT IF THE CYLINDER OR RING LANDS ON THE PISTON ARE NOT TOO TAPERED OR WORN.
