JustAnswerhttps://www.justanswer.com > TV Problems
Sep 27, 2012 - Unfortunately, the symptoms you are experiencing (flashing power/status light, tv won't power on) are generally symptomatic of an internal ... 1 answer Ā· Top answer: p0llinate : Hello, and welcome to justanswer, a pay site for expert technical help. My ...
https://www.askmefast.com > My_nordmende_tv_mo...
Normende tv red light wont come on Nordmende tv blue light flashing Nordmende ... said: nope. will turn on and work fine until the screen dims, goes black.
Thermador oven blue light flashing
When a fault occurs, the control will flash the blue oven "on light" and the Blue "heating light" sequentially to indicate the fault. The fault codes have two numbers, these numbers are interpreted by the number of times the lights flash.
http://pdfstream.manualsonline.com/2/24cb1c7a-813c-4aa7-836b-9488600a6763.pdf
The headphones flash blue when u switch it on.If it flashes blue and red, it means that it is in bluetooth connection mode.So u can connect it with bluetooth devices by switching on bluetooth on your phone or pc.After connecting the red light stops flashing automatically and blue light starts blinking.Hope you understood. :)
Hi, Ephraim. The flashing red light indicates that the device is showing "low battery". It could be that the LG phone charger fits the charging port on your bluetooth headset but it is not compatible with your device. In order for you to know that it is charging, the device should show a steady red light(means charging).
Please take a look at the table reference below.
ā¢With the Charger Plugged In ______________________________________________________________________ ā¢Headset Indicator Headset Status Red-----------------------------------------------Charging (battery level less than 50% charge) Yellow-------------------------------------------Charging (battery level more than 50% charge) Green--------------------------------------------Charging complete
---------------------------------------------------------------------- ====================================================================== ====================================================================== ====================================================================== ---------------------------------------------------------------------- With No Charger Plugged In __________________________
Headset Indicator Headset Status ______________________________________________________________________ Off ---------------------------------------------Power off Three blue flashes------------------------Powering on/off Steady blue --------------------------------Pairing/connect mode Rapid blue/purple flashes -------------Connection successful Quick blue flash --------------------------Incoming/outgoing call Slow blue pulse --------------------------Connected (on a call) Slow blue flash ---------------------------Standby (not on a call) Slow red flash ----------------------------Idle (not connected to phone) Slow purple pulse -----------------------Connected call muted Steady red ---------------------------------Attempting to connect Quick red flash ----------------------------Low battery
Note: After 20 minutes on a call or of inactivity, the light stops flashing to conserve power, but the headset remains on ----------------------------------------------------------------------
Hope that'll help you in some way.
**Please rate my post and/or leave a comment** ...Thanks...
Forgrt it! Our problem is the flashing blue light works and keeps us awake making it necessary to hide the phones in drawers! We can't turn off the flashing blue lights and can't find an answer to this problem.
