Dell 4310WX Projector Logo
R
Richard Wing Posted on Oct 28, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Turn off on screen message
I have a Dell 4310WX projector. I changed the bulb and got an on-screen message saying: Please use an original lamp to ensure safe and optimal working of your projector. I then purchased a Dell OE bulb and the message still displays. I have to clear the message every time I turn on the projector. How do I permanently turn off this message?
ernesto cuadra
Level 3:
Top Expert:
  • Dell Master 12,223 Answers
  • Posted on Oct 29, 2013
ernesto cuadra
Dell Master
Level 3:
Top Expert:
Answers
12223
Questions
0
Helped
4076175
Points
34431
Follow this steps and fix it. God bless you
  • Secure the lamp cover and the air filter cover of the projector body if the projector does not power on. Ensure that the power cable is firmly connected to the projector and an active power plug. If the projector was turned off and then on quickly--let it sit for 90 seconds before trying to turn it on.
  • 2
    Replace the projection lamp if the projector will not power on or if the lamp indicator is flashing. Turn off the projector and let it sit for at least 30 minutes. Locate the lamp cover and remove or loosen the lamp cover with a screwdriver. Carefully remove the projection lamp from the projector housing using the handle, if available.
  • 3
    Place the new projection lamp into the projector housing and secure it to the projector. Replace the lamp cover and reset the lamp timer. Power on the projector to ensure the new lamp is working correctly.
  • 4
    Remove the projector from the enclosed area to allow air circulation if it constantly overheats. Place the projector into an open area and make sure there is no blockage for the ventilation holes. Unplug the projector for at least 45 minutes to allow it to soft reset.
  • 5
    Clean the air filter to allow the projector better air circulation. Turn off the projector and unplug it from the outlet. Remove the air filter cover and use a vacuum to remove dust from the area. If the filter is unable to be cleaned correctly or is damaged, then replace it. Pull the air filter from the projector and place the new one in the now empty slot. Close and secure the air filter cover.
  • Richard Wing
    Richard Wing Nov 15, 2013
    This solution did not fix my problem. It did not even address my problem. The projector works, I just have to turn off the on-screen message every time I turn it on.
5 Related Answers
Anonymous
  • 682 Answers
  • Posted on Mar 07, 2008
SOURCE: Bad Lamp lights even with new bulb.
confirm that it is not made in china-because some chinese lamps is not good in life time.
Anonymous
  • Posted on Jun 27, 2008
SOURCE: dell 2300mp projector
check this out...
http://www.ihatedell.net/forum/phpBB2/viewtopic,p,36316.html
have almost the same problem. lamp light turned on-->replaced the bulb, now when you turn it on tryies to boot and then the lamp light is on again (but the bulb is brand new).... and no light at all coming out of thing... I guess dell just don't know how to built projectors right way.... and theirs tech support guys are.... they just don't know about projectors more then manual
A
Anonymous
  • Posted on Aug 07, 2008
SOURCE: projector
Same problem
When i turn the projector on it only comes on four about a minute until the temp lights go amber and it turns off, the fan is working but the air coming out is a little warm. what if anything is making my projector overheat, or is it not heating at all?
Anonymous
  • 38 Answers
  • Posted on Dec 08, 2009
SOURCE: problem with my dell 1200mp projector
This is a very common problem with these projectors. The fans lock up and the units are out of warrenty. The fan you replace it with must be the exact same as the old one, even though it is the same as a 5$ computer fan. The processor will detect the non-dell fan and shutdown in the same way. I Havent been able to find any replacement fans that will work. I may be interested in buying your broken projector from you if you give up.
Email me at: nalexandrov251[A-T]gmail.com and we might be abe to work something out.
Anonymous
  • Posted on Mar 11, 2010
SOURCE: Hello, My company owns a 3300mp projector, we
I had the same problem exactly. But when I removed the bulb and put it in a working projector it was fine. So now where do I go.
2answers
Projector is not on red light is blinking
check the lamp first
any questions, feel free to contact me
We supply original projector lamp,bulb,accessories,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
have a nice day!
Jerry,Lampdeng Limited
PT-AE4000E projector Panasonic just replaced the lamp but there is still a message that comes up that says heat protection please ref. To the manual and i dont have a manual
Substitute lamp means Temperature is too hight to work
is the lamp is a Original one?
Have a good day!
We supply original projector parts: lamp, bulb, Lcd, Lens, DMD, motherboard, powersupply ... with high quality and competitive price.
Jerry China
Tel: +86 131788 67858
E-mail: [email protected]
Skype: lampdeng.com
YM: [email protected]
http://facebook.com/lampdeng
http://www.lampdeng.com
2answers
My in1 projecter keeps turning itself off
if the lamp has 2000 hors on it, it needs replacing. go into the menu and find out how many lamp hours are used. it could be the lamp and it could be the ballast.
Dell 2300mp projector
check this out...
Projector lamp wil not turn on.
NEVER BEFORE OFFER ON DELL DLP PROJECTOR 2400MP
3000 Lumens Brightness, XGA Resolution, 2100:1 Contrast Ratio
Sony, Sharp, Hitachi, Toshiba, NEC, Benq, Acer, Epson All Are Above Rs 60000/-
Great Offer from Dell Pay Rs 42000/- And You Get
Two Years Warranty +
One Additional Lamp Worth Rs 15000/- +
One Projection Screen 6 by 8 with Tripod Stand worth Rs 7000/- Absolutely Free.
Limited Period Offer.
Please contact at
It gear. In
Shop no 14, Sakhai plaza,
Nr. Kothrud Tel. Exchange,
Kothrud, Pune, India. Land mark- Shree Shivaji Statue. Telephone -020-66021475, Hand Phone - 9850557001.
Contact person- Ketan
www.itgear.in
I have this same projector and am pushing 4500hr on my current bulb. its starting to get a little dim being that the bulb is only rated for 2000hrs. There are brightness setting is the setup of the projector. There are also 4 display modes. game and PC being the brightest. You can change those with the remote. These are the only factors that should effect the brightness. I would say that you might have gotten a bad bulb. try putting the bulb from the "bright" projector into the "new" one and see if that makes a diffrence. also im looking for parts and bulbs for this model projector. If you would like to get rid of anything please let me know. Hope this helps and good luck.
Top Dell Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Ngoro
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
