Check its backlight inverter board. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
SOURCE: Panasonic TC-32lx60
I work for another site that sells service manuals and provides free tech support, and there is nothing in the manual about error codes. The power supplies would need to be troubleshooted. The manual is anew one but if you would like a copy send them an email and they will upload it to the website for you to purchase, they email all manuals that one was scheduled to be loaded to the site this weekend but they will upload it earky if youd like it. Heres the link.
http://servicemanuals.vstore.ca/
SOURCE: 4 blinking lights
I fixed it myself!
I bit the bullet and ordered a replacement Power Board for AUS$290 and swapped it out myself.
Only took ten minutes, most of that time was removing and replacing the 101 screws holding the back panel on!
Working fine again now.
I did sit the two boards side by side and noticed the new one had moved some of the micro components from the back of the board to the front plus some other small component changes.
If your handy with a screw driver and have some technical knowhow I recommend having a go at fixing it yourself as it wasn't hard and probably saved $200 in service charges (all this assuming you are out of warranty!)
SOURCE: Panasonic Plasma TH-42PX60U - power light blinks 12 times
Bad capacitors...! Remove rear panel cover from tv. Most require a star screwdriver. Look for bulging caps in power supply board. (3300uf 10v ) caps need to be replaced with 3300uf 16v. Identify the bad caps.... Caps are bad when they are bulged/bulged and raised. A good Cap is flat X top not raised or buldged. I have pics of what bad caps look like on these boards. Email me if you would like to to see them. Caps cost abywhere from 1-2 dollars or you can buy them in lots of 10 or 12 on ebay for around 8 bucks. Caps need to be soldered on. Do it yourself (if confortable) or take it to a tech/pc repair shop in your local area. Do do that unplug all the wire harness from the board and unscrew the boarda nd take to your teck to solder on the new caps.
You can fix this for about 20 bucks if you have someone else solder or 40 cents if you buy the caps on ebay and replace the 2 bad ones yourself. If one is bad and the other is not replace them both.
The caps go bad because they need to be a higher voltage. 10 insn't enough..... 16 is plenty and don't go any higher than that.
Good Luck
Gunny
SOURCE: WHY MY panasonic tc-50ps14 IS BLINKING A RED LIGHT
I have a 10 blinks and 12 blinks for that set, 10 says it possible SC board, and 12 says Unplug the TV and disconnect connector A11 from the A board. Plug in the TV and press the power switch Does the TV power up and stay on? No Yes If the speakers wires are not pinched, Replace the speaker Replace
the A board
I dont believe that is the issue.
