Does it refuse to do so or does it give an error message?
Three common errors:
SOURCE: TI-84 Plus silver edition sin/cos/tan
for function = (sin,cos,tan,sec,cosec,cotan)
arc(function) = function^-1, calculated in the first quadrant for simplicity(0-pi/2) (0-90deg), as all functions repeat circularly
just another method of notation
http://www.mathwords.com/t/tangent_inverse.htm
SOURCE: Using Cos/Sin
Calculator turns on in "degree" mode. Just enter angle in degrees then press "SIN", "COS" "TAN".
Most people work in degrees but you can switch to Rads or Grads to Degrees modes by pressing "DRG" repeatedly with zero displayed, Current angular mode will show in display.
Get a new instruction booklet by download from TI website
SOURCE: how do i use the inverse log operation on the TI-84
The problem is simple. You're trying to get an [H+] concentration which is obviously going to have a value of some number times ten raised to a negative power. Therefore, you have to insert the negative value of the pH into the 10^(x). When you insert said negative number you will come out with the right answer.
i.e.
The pH of a sample of human blood was calculated to be 7.41. What is the [H+] concentration of the blood?
10^(-7.41) = [H+]
[H+] = 3.9 E-8
(the answer should only have two sig. figs because the pH has two digits after the decimal.
SOURCE: How do I calculate the inverse log on the TI-89?
The wrong terminology is playing tricks on you.
Exemple: What is the antilog ( that is the name, not inverse log) of 0.345?
Answer; antilog of 0.345 = 10^(0.345) =2.21309471
Look at the last two commands on the screen capture.
Hope it helps
Thanks for using FixYa
SOURCE: Using the correct key combination to determine inverse log
Sorry to contradict you but there are many types of logarithms, the most important ones are
On calculators, the common logarithms are labeled [LOG], and the natural logarithms are labeled [LN].
The inverse function of the natural log function is the exponential (e^(x)), and the inverse of the log in base ten function is the function ten to the power of. It is called (sometimes) the antilog
Ex:
Question What is the antilog of 3.5678?
Answer The antilog of 3.5678 is 10^(3.5678) = 3696.579068
Verification: log(3696.57908) =3.5678
Hope it helps.
SEC, CSC & COT are the INVERSE of COS, SIN & TAN and are usually require hitting the "2nd F" or "Func" key of the calc to make:
SIN button work as COSEC,
COS button work as SEC
TAN button work as COT
Formulas are below:
sec x = 1
cos x
cosec x = 1
sin x
cot x = 1 = cos x
tan x sin x
