The popular Kwikset keyway is used by many companies, and will fit into one of Lockwood's keyways. The spacing is a little different, so if you are trying to make locks of both brands work with the same key, double check the width of the cuts while you have the locks apart to make sure the pins you are using will sit on the bottoms of the cuts and not on the slopes of the sides of the cuts.
If you just want to copy a key, then there won't be a problem. Lockwood does have 6 and even 7 pin locks, so make sure your key is the right length.
