SOURCE: touch screen is freezed
whilst the phone is on take the back cover off and disconect the battery this should reset the phone , replace the battery and start as normal. Also the phone slows down if you have not deleted your text message inbox,sent box, deleted box so keep on top of that and clear your cookies if you been on the internet.
SOURCE: Touch Screen is unresponsive.
If Verizon doesn't replace it for you, you can find the touch panel at Droid Repair and there is a guide that shows you how to put in the part at Droid Repair Guide.
SOURCE: my droid 2 keeps freezing and shutting off and the
hi tazrahzeljr3 listen the best thing to do is to take the battery out of the phone.first.Then put it back in the phone . Also I want you to go to contacts and export them to your memory card. Also you should have a 16gb memory card in the driod and not a 2gb memory card. If you brought the phone brand new should take it back and get a replacement right away. Hope this help
I’m happy to help further over the phone at https://www.6ya.com/expert/ronald_e152e07e272e4f27
Testimonial: "thanks alot ive tried almost everything now. I think ill just call wirefly to see about a replacement. Thanks for the quick response tho you rock!"
SOURCE: My htc evo will not
Re-install the firmware (http://androidforums.com/htc-hero-sprint/45596-how-reinstall-os.html) if that fails, there may be a hardware issue. If HTC doesn't help you, here's a guide on how to disassemble an HTC Evo. Maybe a tech savy friend can do it for you. If you want to pay to have a service do it for you there are third party HTC Repair Services.
SOURCE: my htc surround (windows 7
PLease do a hard reset on the phone and here is how you do it
1. Turn the phone off. If it's frozen or unresponsive, pull then replace the battery.
2. Press and hold the Volume Up and Volume Down buttons and power the phone back on.
3. Continue to hold Volume Up and Volume Down until a factory reset screen appears.
thank you. i'll try just dat!
