Kenmore Master
- Posted on Jan 02, 2010
Re: Water is leaking on the top shelves in my kenmore...
The drain in the freezer is clog make sure the drain from the freezer
is clean all the way to the pan next to the compressor . you need to
open the back wall of your freezer for that ( the inside wall) clean
with buster (water pump)the drain is in the bottom middle of the freezerr
WATER IS LEAKING FROM THE FREEZER ON TO THE TOP SHELF IN THE REFRIDGERATOR
Water is leaking from the top of the fridge (from the freezer?) - it pools on the shelves and collects under the vegetable trays. Also, at the same time, the freezer is not cold enough and food has thawed in the freezer. Do I need a new fridge or can this be fixed?
