Sewing Machines Logo
C
Cynthia Duram Posted on Oct 27, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Bernina buttonhole 730
I cannot find the button hole sensor and need to make a button hole without it. How do I do it?
sylviaivie
Level 3:
  • Husqvarna Master 1,564 Answers
  • Posted on Nov 01, 2013
sylviaivie
Husqvarna Master
Level 3:
Answers
1564
Questions
Helped
426037
Points
3583
Use your ruler and measure your button. Then transfer those measurements to your garment.
Use chalk to mark the center cut line of your button hole. Mark the end or stop point of the button hole per the measurement.
Practice on a scrap of the same fabric before you begin on your garment.
Set your machine the satin stitch zig zag at a fairly narrow width.
Begin satin on one side of the center line of the mark. Slowly stitch down that side until you get to the end. STOP. Widen your satin stitch to the max. sew about 1/8" and stop with the needle down on the opposite side to your first line of stitching. Turn the fabric, narrow the stitch to match original satin stitch. Sew slowly down the other side of the center mark. STOP, lengthen the stitch, sew 1/8" then do a couple back stitches.
That's one way. Another older way is to sew 2 or tree straight stitch lines around the center line. Remove then use a hand rendered button hole stitch after you cut the hole.
5 Related Answers
A
Anonymous
  • Posted on May 23, 2008
SOURCE: Bernina Activa 131: buttonhole problem
There are TWO buttons on the machine that have the little u-turn on them. Look for the other one. That is the one that makes the second half of the buttonhole. Look in the owner's manual, it may tell you where it is on your machine. I spent a long time swearing at my machine before I figured out that the reverse is not the only button with the u-turn arrow. The manual is not clear on this. Why they use the same symbol twice is beyond me. Mine is on the front of the machine, down by the needle. Hope this helps.
Anonymous
  • Posted on Oct 16, 2008
SOURCE: BUTTONHOLES
Yes, If you have a zigzag function use that. First you must keep the zigzag function stationary then set it to about a one or two on the stitch dial. Try that!
Anonymous
  • 52 Answers
  • Posted on Jun 25, 2009
SOURCE: Bernina Aurora 430 utomatic button hole
Take it to your local bernina dealer and have them calibrate the buttonhole foot along with the speed control.
Anonymous
  • 8 Answers
  • Posted on Sep 06, 2009
SOURCE: Bernina 730 Can't open top cover !
The problem is that of a stuck piston detent on the pattern selector support that snaps the top cover closed.
  1. Open the light cover
  2. Apply pressure with thumbs on the bottom edge of the top cover on both the right and left sides of the cover. The cover should pop up...Too much pressure on the left side, (if this thing is really stuck) and you might break the top cover at the thread tension slot. Be careful here....
  3. Add a drop of acetone (fingernail polish remover) to the piston detent and work it free by pushing it back and forth. Avoid getting any acetone on the painted surfaces of the machine.
  4. Continue to work free, repeating with a few drops of acetone, and wipe clean. Don't oil this part. It was a petroleum product combined with a galvanic process (aluminum and steel) that caused the problem in the first place, not to mention age.
  5. Use DTE Heavy Medium oil rather than a white or clear oil when you lubricate your machine. White oils are unstable and will oxidize (decay) much more quickly. Also avoid 3 in 1 oil and stuff like WD40....very bad....
  6. Oil 1/2 a drop on those prescribed areas. Too much oil is more harmful than not enough....
  7. Contact your Bernina dealer for this oil.
Testimonial: "To swiss_tech Great help. Very much appreciated. Thank You"
Anonymous
  • Posted on Feb 04, 2010
SOURCE: Bernina 730
I have lost the cord lead to my Bernina 730 sewing machine and cannot get any spares locally. Can anyone out there help find a replacement.
How do I make buttonholes on the Bernina 180?
I don't know about your Bernina but mine you have to manually set the button hole size every time you do a new button hole size. Practice on a scrap bit of fabric. I think you push the buttonhole button - sew which I think does an end, push the button again, sew for the distance forward you need and push the button again, and sew the other end and push the button again and it should go back to the beginning. That's off the top of my head, I could be wrong but try it on scrap. I think it might then have set the size until you change stitch types and it should continue to do the same amount of forward and back stitches with each button press to tell it to go forward, end, back, end etc. But practice! My machine has trouble feeding the fabric evenly.
Bernina 730 button hole knob stuck
Machine needs a good cleaning and oiling. Might try directing hot air from a handheld hair dryer into internal mechanism concentrating on the selector knob mechanisms.
Frozen button hole lever Bernina Record 730
Most likely needs a good cleaning and oiling. The old oil has turned gummy and has frozen the selector knob mechanism. Might try directing hot air from a handheld hair dryer into the interior mechanism toward the buttonhole mechanism to help get the old oil loosened. (Even if it comes loose with hair dryer, it still needs a good clean/oil to keep it all working.)
How do I make a button hole with my Bernina Activa 140?
If you go to http://www.bernina.com.au/webautor-data/888/0305295204_0303_a135-a145_EN.pdf you can download a manual for the Activa 145, I suspect that the instructions would be very similar for buttonholing.
5helpful
2answers
How do I use the button hole foot on the Bernina 807 minimatic?
There isn't an automatic button hole on this machine. You can do it manually. Thread the bobbin thread as usual, but put it through the little hole on the hook in the bobbin case. Set the stitch length between 0 and 1, like a nice satin stich. Set the needle position to the far left and the stitch width to 2. Sew down the left side. Center the needle, set the width to 4 and lower the feed dogs, stitch about 6 stitches across the bottom. Then reverse the direction, set the needle to the right, stitch width to 2 and go back up the right side. Lower the feed dogs again, set a wide stitch and finish the top.
Another good option is to buy a universal presser foot shank from Bernina and then attach an old cam type buttonhole attachment from Singer. They make beautiful buttonholes and you can even do a keyhole button hole.
I can only sew the first bar of the buttonhole. When I press the securing button nothing happens and the machine carries on sewing the first bar. I just cannot make any of the button holes work. Can I do...
I can't be specific, but I had problems with my Bernina Virtuosa 160 automatic buttonholer.
Check the feeddog teeth height. At their highest point, the FRONT teeth height should be 0.05mm higher than the back teeth.
Good luck.
Esther. England.uk
1helpful
Bernina Buttonhole foot #3A
Difficult to say whether your current foot can be repaired or even if a new foot is the answer. I believe the auto buttonhole needs to be calibrated to the machine, but not sure that is the issue with your machine.
You can sew a buttonhole without using a buttonhole foot--not really difficult as that's how it was done for many years before the manufacturers developed the specialty foot. (My machine came with a buttonhole foot but I still make mine the old-fashioned way because I determine how they will look rather than the machine making that choice for me.)
Practice a few times on scrap fabric and write down the stitch widths & lengths that work the best for you so you can replicate each stitch to look alike.
How to make button hole
l Until Wednesday Calls How To Manual Machine Buttonholes
Manual Buttonhole Settings
How to sew buttonhole with an old machine
How to Sew Button hole tutorial (this is my least favorite method)
Sew Buttonhole without Buttonhole Foot by Create Kids Couture
(also don't care for this type--don't like the look when the fabric is rotated and stitched across the end of the buttonhole--the bartacks on the other buttonholes is much more professional)
Sewing Buttonholes Without Buttonhole Foot
Buttonholes without using special feet or cams YouTube
How to Sew Buttonholes with Regular Foot Sewing Tutorial with Alison Smith (this creates a much more professional looking buttonhole)
Top Husqvarna Sewing Machines Experts
ZJ Limited
ZJ Limited
Sean Wright
Sean Wright
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
