Have you got the hot water pipe on? the water can sometimes flow back out this valve if it is not plugged.
has it been serviced recently? there is a pressure pipe that attaches to the side of the bowl, and a pump that need to be secured or you will get a leak from the bottom.
if is has become loud on spin recently, it could be that you have a leak from the main seal, and will need bearings replaced aswell, but that model seems a bit new to need bearings already, but it's not impossible.
This is a good question; what brand of washer machine do you have?
Is it front or top load?
Leaks water from the front door, from where you load the soap or from the back or bottom?
If it is from the front door it could be the gasket, if it is from where you load the soap it's the same soap clogging the fill hose, if it is from the back it could be the hoses or the fill valve, if it is a top load and you see the water liking from the side or bottom, then, if it is from the side the fill hose is your problem if it is from the bottom then it could be the seal from the drum or just a leaking pump.
Please be more specific
