I own a Sony Bravia 32r423. bought it for it's DVB option. the monitor isn't connected to nothing but electricity. every time I'm going to the dvb option I get an error - "Feature not avalible". I know for fact there is a DVB reception in my erea. what to do?
SOURCE: DVB PROBLEM WITH Panasonic- TH50PX600A
theres this panasonic tv that when i turn on it shows no picture and sound and makes a noise how can i solve that problem?
SOURCE: OSD on Sony Bravia
Depending on the models of your units, there are some software/firmware upgrades for specific units to adresss this particular problem. Check the Sony website under support to see if any software/firmware upgrades are available.
SOURCE: Sony Bravia LCD TV is tripping the fuse in the house
These things draw a huge surge current when turned on. What size fuse are you blowing? These things can surge 10-12 amps on turn-on. What about a fuse with a reset button. They will take alittle more surge before they go. Don't matter about the insignia working before because the cheaper sets tend to stay powered up more when off....thus not surging on from a dead start. Could you try a different plug on a different circuit/fuse? and see if that makes a difference. If you have a 15 amp fuse, then your pretty close with other stuff plugged in. What size is your service? Do you still have an original 60 amp box with screw in fuses? Is it an old house?
SOURCE: my Sony Bravia LCD TV KDL-V40XBR1 doesn't turn on
You need to do some troubleshooting before buying any parts. Basic LCD monitor and TV troubleshooting guide: Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
