Question about LTD Watch Bowflex Strapless Heart Rate Monitor watch
How to set time on bowflex strapless heart rate monitor
Instructions for Bowflex WR30M?
In time mode, hold set (bottom right button) to change date and time. The selected (flashing) item can be changed in one direction only using the up (top right) button. Press set again to cycle through each item until desired settings are chosen.
In stop watch mode, the up button starts and stops the stopwatch, the set button will take a split time while the time is running. To reset the stopwatch, press set once while the time is stopped.
In alarm mode, the up button turns the alarm on and off. There are three alarms available. To cycle though alarm times, press set. To set an alarm, press and hold set until the time flashes, then set the alarm time using the up button, cycle through hour and minutes using the set button. When finished, press set again.
Timer mode. To set the timer time, press and hold set until the time flashes. The timer goes up to 23h:59m:00s. You cannot set seconds. Once set, the timer can be started and stopped using the up button. There is no reset for the timer, to start a new timer the time must be manual changed again.
To check heart rate, press and hold mode until PUL is shown, place two fingers, one each on the top and bottom metal contacts for 6-10 seconds to get reading (This works best when not in motion).
Apr 13, 2012 | Watches
I own a bowflex precisionxt heart rate monitor and I cannot find the manual. Where can I obtain one?
Try this:
search-manual-online.com/bowflex-precision-xt-heart-rate...
Aug 29, 2011 | Watches
MIO MOTIVA STRAPLESS - My problem is that the watch is brand new out of the box, but the actual top right button (Start/Stop/-) doesn't work. Also the actaual sensors don't seem to be picking up my pulse...
Unfortunately MIO do not have repair services in Australia, probably would have to send it back to the US. Hopefully you can work with the seller to fix the issue. I know when you buy through mioglobal.com their customer service is excellent.
Mar 30, 2011 | Mio Motiva Strapless Heart Rate Monitor...
I have a mio watch,installed new battery.hear rate monitor does not work,much too high
Have you contacted their customer service team? They are great at resolving issues and really stand behind their product. Their Facebook page MIOWatch also has lots of troubleshooting and FAQs too.
Nov 13, 2010 | Mio Motiva Strapless Heart Rate Monitor...
I lost the directions to my Motiva heart monitor watch. How can I find it on-line?
Thank you for contacting FixYa.<br /> Motiva is owned by Philips. You can download at the following link:<br /> <a href="http://www.healthcare.philips.com/us_en/products/telehealth/Products/motiva.wpd">http://www.healthcare.philips.com/us_en/products/telehealth/Products/motiva.wpd</a><br /> Best regards.
Aug 25, 2010 | Mio Motiva Strapless Heart Rate Monitor...
Reebok Strapless Quick Touch Heart Rate Monitor Watch (Reg. Size)
Have tried going to a watch shop ? It may sound a bit obvious, but looking at your watch and comparing it with mine, I think that a standard strap might fit.
You have nothing to loose by asking and it tends to be expensive to send them back to the makers.
Feb 16, 2010 | Watches
I have a mio euorfit heart monitor watch. During my workout I
Yes, you definetely need battery replacement.
As the hart rate monitoring is most sophisticated part of the device, it has more IC (Integrated Circuits) than any other features.
More IC's means more power is needed, so, if the heart rate monitor is starting to malfunction, that's the very first sign of underpowered battery.
Find your nearest watch repair shop and ask for battery replacement.
Do not forget to rate, please.
Jan 23, 2009 | Mitac Mio Fit Heart Rate Watch
LTD Watch Bowflex Strapless Heart Rate Monitor watch Logo
65 people viewed this question
Top LTD Watch Watches Experts
Arturs Kalnins
Arturs Kalnins
Marvin
Marvin
Are you a LTD Watch Watch Expert? Answer questions, earn points and help others
