First: You need to check a Upper Rubber Gasket (fits around the top puncture pin). If it missing you will have leakage because here's no seal to protect leakage. You can buy it online or call Keurig Customer Service (if you still have warranty)
Second: Upper Rubber Gasket not making a seal with the K-Cup or Reusable Filter and the water and/or coffee grounds leak out. To fix it simply move Upper Rubber Gasket 1/4" down. This should close the gap between K-Cup and upper needle.
SOURCE: Keurig starts & stops without brewing coffee, just descaled
The pic is clogged with coffee or the air bladder is bad. Use the tool on the underside of the tray to clean out pic. If that doesn't work, the bladder will be bad.
SOURCE: We have had our Keurig
Sorry to read about your problem, I hope this helps you out.
It sounds like you unit has a major malfunction. and they do break
Keurig does not make repair's or carries replacement parts for their units. you can contact Keurig at 1-866-901-2739 or Keurig.com
You do have a 1 year warranty, and if you are out of warranty. They will give a discount on a new unit.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Testimonial: "Thanks for the immediate response. I will contact Customer Service at the telephone no. you gave me. Hope I get a good response from them. "
SOURCE: I received a Special Edition Keurig for Christmas.
I had a similar problem, I solved it by removing the K-Cup holder assembly, and pulling the small bottom piece off (it just pops off easily). From there you can access the "Exit Needle", which is where the coffed comes out and which is prone to getting clogged with grounds. Once you pull that bottom piece off you can run a paper clip or something up through the bottom of the needle and dislodge any clogs. This procedure was listed on page 13 of my manual and worked great!
Here is a tip that I wrote
that will give you some things to try that will help you get your
Keurig coffee brewer working again.
Keurig
Coffee Brewer not making a full cup of Coffee
heatman101
Keurig
heatman101
Ok, so I've tried cleaning out the needles. It still won't brew. I doesn't even go through the k-cup. Just starts running out the top. Guess I will have to contact Keurig and see what can be done. I've only had my brewer about 4 mos.
