My 28" Snapper Rear Engine Rider does not seem to want to move forward in 3rd gear or less unless I push it with one foot while mowing. When I put it in 5th gear it moves forward slowly,but then seems to pick up speed.
If its the disc driven snapper I believe it to be, then you need to replace the rubber fly disc. Or- check the linkage where the tran bar slides.
craftsman rider will not move with manual push lever in or out and will not move with engine running either
Just got a 30" rear engine Craftsman rider 420cc model 290000. When i try to mow in reverse the engine shuts off. Is there a way to override whatever is causing this.
