Had major melt of plastic tray in oven, did self cleaning process for clean up. Now it won't heat.
Hello John, thank you for allowing me to assist you!
I understand your wall-oven is no longer heating. The
wall-oven has a safety thermal to prevent the oven from overheating. If the
unit will not bake or broil, more than likely the safety thermal has tripped.
Other possibilities are incorrect power supply or faulty main control board. I am fairly confident that an
authorized service agent will be able to restore your appliance to its normal
operating condition. You can often locate a qualified service technician on the
manufacturer website.
Best
regards!
SOURCE: Oven door remains locked after completion of self clean cycle
My oven door stays locked , when I press the clear button I get F1?
I hold the clear button for a few seconds and still nothing.
Please,
Thank You
SOURCE: Frigidare Self Clean Oven
I JUST CALLED FRIGIDAIRE AND GOT INSTRUCTIONS FOR SELF CLEANING:
1. TAKE OUT THE RACKS UNLESS YOU DON'T MIND THEM TARNISHING
2. TURN THE "SELECTOR" AND/OR "OVEN" DIALS TO THE LOCK (OR CLEAN) POSITION
3. PRESS THE "COOK TIME" BUTTON
4. SET THE CLOCK TO 2 OR 3 HOURS (I.E., "2:00" OR "3:00"), DEPENDING ON HOW DIRTY THE OVEN IS
5. PRESS "START" BUTTON
6. YOU WILL HEAR THE MOTORIZED LOCK MOVE INTO PLACE; WAIT ABOUT 30 SECONDS, THE DOOR SHOULD BE LOCKED AND CLEANING WILL BEGIN.
7. CLEANING WILL STOP AFTER THE TIME SELECTED (I.E., 2 / 3 HRS) AND THE DOOR SHOULD AUTOMATICALLY UNLOCK
SOURCE: Frigidaire oven overheating
I would say that the oven thermostat is malfunctioning, and you will probably need a new one fitting.
Make sure the sensor inside the oven has not become detached, as this will make a differance.
Plz leave feedback.
Ta.
SOURCE: frigidaire self clean electric stove 'f9' message comes on when self cleaning
I had the same problem. All I had to do was clean around the door lock. A small bit of burnt food or something had gotten into the hole around the lock and prevented it from moving all the way into position. Took a tooth pick and 30 seconds of probing to clean it out. Works fine now.
SOURCE: self clean lock
Hello there:
Normally every body gets this almost right by cutting the power but there is a trick to this it can be done in 2 different ways depending on the unit
First unplug the unit and wait 15 -30 seconds then plug it back in and wait for 15 to 30 seconds then unplug it again and repeat this step 1 more time then upon the final plug in wait for 5 min and then unlock as you normally would.
now on the newer units the trick is to let it stand unplugged for 1 hour to allow the internal reset device to reset the appliance then plug it back in and then wait 5 min and you should hear it automatically unlock the appliance or you cn simply unlock it as you normally would
BUT REMEMBER DO NOT TOUCH IT FOR THE 5 MINUTES AFTER THE PLUG IN STAGE OR YOU WILL HAVE TO DO IT ALL OVER AGAIN OK
Hope this is very helpful for you please keep me posted on how this is going there is still more that i can show you but i wanted to start with the basics ok?
Best regards Michael
