SOURCE: I have a two man Ozark tent. How do I set it u p?
Two poles. They pass up through the sleeves on the outside of the tent, across the top, through the sleeve on the diagonally opposed side, then each end is stuck into the pocket attached at each corner. They cross at the top. Then the small rain fly attaches with bungees over the top.
SOURCE: coleman salt lake tent 9 man no instructions please help?
the instructions are useless anyway. you put the red poles through the 2 side bedrooms. the black rods and the black poles with the bends in join together and go diagonally through the middle of the tent. the yellow rods join together with the black poles with the yellow tape round the ends and u fit these from the inside of the front and back entrance then when the tent is up you just hook the bedrooms in. hope this was usefull
SOURCE: I have a Thermos
I have one of these tents, here is how you operate it. When you pull down to set the tent, pull down on the larger fatter end. When releasing, pull down on the skinny side. I use the canvas bag to pull it down. That makes it easier on the hand. Or use work gloves.
Good luck
J
SOURCE: I need an instructional manual
Hi there.
You will be able to find the instruction manual of hillary 3 dome tent when you visit http://www.hillary.org
Just click the Hillary Tent on the category and it will lead you to the instruction manual.
Regards.
