Televison & Video Logo
r
rose martinez Posted on Oct 27, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Remote won't program tv. - Hisense TC24FS2H TV
Level 3:
Top Expert:
  • Hisense Master 76,851 Answers
  • Posted on Oct 29, 2013
Hisense Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
14994792
Points
237762
Check the remote control for its infrared emission. If found OK, check and replace the infrared sensor in the TV. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Cannot program LG TV to my remote. None of the codes work and it won’t allow me to manually program a code
If this is a Universal Remote, nobody does that any more. Buy a facsimile remote made for you LG television.
Google
make model replacement remote.
They should all allow you to enter codes manually. Send it back as faulty.
3 Digits Universal Remote Control Codes For LG TV
  • 520.
  • 512.
  • 506.
  • 505.
  • 627.
  • 615.
  • 653.
  • 766.
More items...
May 15, 2020
LG Universal Remote codes and Programming for TVs
How do I find Colby tv codes to program into a rca converter box remote
RCA converter box remote control have no set-up code to Coby.
Atlas ocap
use the camera digital or cell cam and with the remote control viewn see if the LED are ON. see the photo attached.
If do not do it. Open the remote control clean the keypads from corrosion, and resolder any colder joint . clean the contacts batteries and try again.
Won''t turn on the tv also cannot change the settings manually on the tv
Thanks for stopping by.
What is the model number and manufacturer of the TV you are trying to control with the CT-90157 remote?
Not all IR codes are programmed into all remotes.
2helpful
Will my tv remote work on my converter box?
If the tv remote is the original TV remote, it won't control the converter box (if this is an digital-to-analog converter). If it is another remote, then maybe. It depends on the remote and when it was programmed.
Most remotes are limited to codes for devices released at least 6 months before the remote was programmed. Thus is your TV remote was programmed in late 2006, then it may have the right code. Some universal remotes support the converter boxes; others don't. If you provide additional information on the remote, I may be able to give you more specific details for your situation.
I hope this helps.
(any tv that requires a d-t-a converter box was built before any plans were finalized for the converter box.)
2answers
RCA universal remote RCU703SP wont program Magnavox TV
cheap universals dont hold as many codes, the best universal remote is the all for one range with the best being the comeleon
Unable to program year 08
8 key broken on your remote? try a universal remote.. if not then the people who programed in the years into the tv figured that the tv wouldnt be in use in 10 years so they stoped programing at 07' ... not really a whole lot you can do there but deal with it or buy a new TV. sorry =(
Remote
this is from your producer: Product Description ? BASIC OPERATION OK ? everyone knows what a handheld remote control unit does for your home electronics. You can control your basic four (4) components: TV, DVD player, VHS player, Cable or Satellite tuner. Setup is simple for these basic 4? put in the batteries, look up the manufacturer of your component (Mitsubishi TV) and note the possible 3-digit ?program codes?? turn on the component, press the remote control?s PROGRAM button until the light stays red, press the component button (i.e., TV), enter in the ?program code?, and press the ?power off button? ? if the component (i.e., TV) turns off: you are programmed! If the component (i.e., TV) doesn?t turn off, then repeat the sequence using another of the manufacturer?s program codes until it does. Easy ? took me about 3 minutes to program my old Zenith TV (in the bedroom), my SONY DVD player, and my Mitsubishi S-VHS player. No problems at all. HOWEVER, in case you do run into a component for which the ?program codes? don?t work? you can go through a sequence to self-identify the coding. While I won?t go into it here, it is only slightly more time consuming than the other method. As my codes worked fine, I can not address this aspect, so I won?t make a claim we didn?t test.
Top Hisense Televison & Video Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
