SOURCE: Asrock P4i45gv motherboard problem
i am remove the motherboard & plaste the headsink inthe cpu cooling fan then start my computer cpu fan is running but no cpu heet no beep sound
SOURCE: Motherboard: MSI 880G-E45 CPU: AMD Phenom
the beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off. make sure that your RAM is securely seated One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive Test all leads that attach to your hard drive including electrical extensions,IDE,SATA the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty a computer needs its connections to continue its cycle and to have and end to function
obvisously the beeps are windows searching for some hardware it could be RAM cd/dvd hard drive or motherboard all of these must have secure connections for the computer to work
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure make sure the connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
hope this helps
