Is the fill tube clog? the ice maker is not going to harvest mode. Take the ice maker cover off and put a jumper on T and H hole the dial will turn and wait until you hear the click remove the jumper. make sure you have gloves on. Do this at your own risk, if you are not sure call a servicer. If the dial won't turn you have a bad ice maker (if you have a 115 volts to the ice maker).
SOURCE: We have a maytag refrigerator
Emptyed out freezer unit & shut it off. Took a hair dryer and blew hot air for about 3 minutes on ice maker unit just in case it had an ice block. Left door open and let is stand for about 10 minutes. Turned everything back on and it started making ice.
Carol
SOURCE: icemaker not filling with water
Try
using an hairdryer or defrosting the unit completely , this often get
rid of blockage caused by frozen lines fixing the problem.
The water lines can also be unblocked from dirt using a thin flexible shaft. This after defrosting.
If all that does not fix the problem, then you may need to replace the
water valve, the icemaker solenoid, or the whole icemaker assembly.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
SOURCE: MAYTAG MFI2067AES ICEMAKER NEEDS REPLACING
2 things possibly: check brackets and see if they need to be moved inward or outward as in they have bracket catches on the brackets so when you remove the screws the icemaker just doesn't fall off the wall of the unit,also check the center of the machine you may still have a screw holding the assy thats hidden
Hi
Please check the water inlet valve, it might be frozen or blocked
with mineral deposit. Use a hair dryer to remove the blockage. Make sure the
water inlet valve's screen is not blocked. If the issue persists, then the
water inlet valve has gone bad, use a multimeter to test the water inlet
valve's continuity. Use a multimeter to test the continuity. Hope this
helps...please post back for further assistance.
Daniel
