Check and replace its audio output IC, or audio output card. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
SOURCE: loud whisle for five minutes
mine did this it is the power supply it cost 270.00 to fix part and labor
SOURCE: my 32 inch polaroid tv just shut off
Repaired dead Polaroid TDA-03211C
I fixed a dead Polaroid TDA-03211C for my friends. When it failed it had just been turned on and then it went totally dead. This unit is a little over a year old and out of warranty. When I inspected the power supply it was continuously trying to start up but could not. With a Fluke meter you could see some of the DC output voltages rapidly rising and falling, but never getting to normal levels. I pulled the power supply thinking some of the capacitors were bad. Once I had the power supply out I used the Ohmmeter to check for any open or shorted diodes and/or transistors. To my surprise I found a shorted diode! I figured it would be the capacitors (typical failure in switchers), however they looked OK (not leaking goo or puffed out) and the TV is not that old. The failed diode (sorry I forgot to get the circuit designation) is a HER-304 (near the middle of the board with the cathode lead soldered to a small silver colored heatsink). The HER-304 is a 300 Volt, 3.0 Amp High Efficiency Rectifier in a DO-27 package. The DO-27 package is cylinder shaped with axial leads, 0.375" (9.5mm) long and 0.197" (5mm) in diameter. This diode is for the 20 volt source and is connected to one of the secondaries of the transformer. On eBay I found a vendor selling five (5) HER-305 (400 Volt units, better than the original) for $1.25 plus $7.95 shipping. Also I checked most of the Capacitors with a Sencor Z-meter, all that were check were OK. If a Cap. had another in parallel with it I did not check the other. I removed (un-soldered) the heatsink from the board and then the diode from the heatsink. I put it all back together and Yes, under $10.00 in parts (actually a $0.25 part) and a little time and the TV works again! 24 July 2009.
WARNING!!! WARNING!!! WARNING!!! Switch mode power supplies such as this use and generate voltages at current levels that can be LETHAL!!! If you DO NOT know what you are doing, find someone that does or buy a new TV, it is not worth dying for!!!
SOURCE: TV TURNS ON HUMMING SOUND FOR ABOUT FIVE MINUTES AND GOES AWAY
go in audio section and select mono instead of stereo or sap
SOURCE: Our TV has a loud
Hi
A common problem for these is bad capacitors in the power supply, Remove the back from your Tv and look at the power supply on the left hand side.
You will see roughly around 9 x capacitors that are bulged / domed shaped on top usually these are valued at 3300uf 10V any that have bulged or leaked a brown like substance should be changed.
This will cure the problem as they overheat being sat next to a heatsink that gets very hot!
Try and change them for the same 3300uf but a higher voltage.
Hope this helps
