Microwave Ovens Logo
Asha Pawar Posted on Oct 27, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
H5460NO/01 door lock is not working - Microwave Ovens
ernesto cuadra
Level 3:
Top Expert:
  • Microwave Ovens Master 12,223 Answers
  • Posted on Oct 28, 2013
ernesto cuadra
Level 3:
Top Expert:
Answers
12223
Questions
0
Helped
4078132
Points
34431
Test this steps and fix it. God bless you
  1. Open leverCheck your microwave lever to determine if it is damaged. If it is broken, simply replace the lever to get your microwave door fully functional again.
  2. Door springResponsible for keeping downward pressure on the door hook, the microwave door spring can begin to malfunction. If this part is broken and prevents you from opening your microwave door, replacement is necessary.
  3. Door latchOne reason your microwave door may not open properly is a broken door latch. Located inside the microwave, the door latch manipulates the door hook to keep the door closed for safety and top performance. If broken, the door could become stuck in the locked position.
  4. Door hookIf your microwave door will not release properly, the door hook could be damaged. Located inside the door, the door hook is made of plastic and prone to breakage with extended use or age. As this part is unable to be repaired, the only option is to replace it.
  5. Button or button springIf the microwave door will not open, it could be an internal failure of the button or button spring. If it is determined that either of these parts is the source, both are replaceable and it is recommended that they be installed at the same time.
  6. Handle actuatorIf the microwave door will not open the plastic handle actuator could be broken. Connected between the door button and the door latch assembly, this plastic part could become damaged and brittle over time, which makes breaking inevitable. If this occurs, replace the handle actuator to get your microwave fully functional again.
Tappan Speedwave 1000 turns on when door is opened
Microwaves do normally 'turn on', in that the light comes on and the fan starts running. If the turntable starts turning and it is emitting microwave energy, then you need to take it for service or replace it. To me, it sounds fine.
Kenmoore Microwave Hood Combination Door not locking.
If you wish to get some details about microwave oven working principle an repairing ; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
How do I replace jvm1490sd broken handle?
Disconnect, open door, remove screws from rear of door, dismantle door. Here's a diagram showing how it fits together.
01 Control Panel Door Grille Case Parts for GE JVM1490SD003
The part you need is #1801 on diagram
Microwave Door Handle
Color: Black. For white order WB15X10070. For bisque order WB15X10071. For the screws order WB01X10305.
by GE
Part Number AP3184331
2helpful
Mbbs 01 thermador micro oven: timer counts down, lights go on, but no heat, no fan and turntable does not turn. is it a fuse?
Key clue is table does not move---All microwaves with a table have a lever switch that is engaged when door closes--only can get at from inside the unit----it prevents the unit from operation if door not closed.
What happens from closing door a lot is the switch with a lever arm can come loose or even if snapped into a plastic holder break out of the holder.
IF this it is not too expensive a repair.
Not Heating. Fan, turntable, light working.
I would definitely suspect the door locking mechanism in this case. If it was the sensor it would start and then stop within a short time.
The starter switch should click if you have the door open and time it for 01.seconds and press start. So that is the secon component to think of.
2answers
Microwave runs when door is opened
Dont run it with the door open....The microwave are not good for you...You have an interlock switch problem...They can be adjusted...Sounds like one is stuck or bad in the closed position...Again do not run with door open......
Will not heat anything
This is not lock child feature, you reset lock child uunplugging power.
Test the high voltage capacitor, the rectifier diode.or the magnetron. If all this are fine, test the control board.
If it additionally does not spin and no light, then check also the door switch and fuse.
The diode and capacitors can br tested. The capacitor must be allowed discharge before testing, or you risk to get electrocuted, even if power is off. Capacitors can get discharged by shorting their two contacts.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts. (here in UK).
DOOR SHOWS OPEN BUT IT IS NOT
After self cleaning the range the door won't open....
The oven door lock needs approximately 1 hour to cool down before the oven door can be opened after a self cleaning cycle has finished. If the lock does not open after the oven has cooled down, you can try....1) Unplugging the range or shut off the circuit breaker for 5 minutes. Plug the range back in or turn on the circuit breaker. Set the clock and try moving the door lock lever or opening the door. 2) Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever or opening the door.
Hope this may help;
DON'T FORGET TO HELP
Top Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a Microwave Oven Expert? Answer questions, earn points and help others
