Have cycled power, cleaned sensors, still will not fill. Any ideas?
Also looking for help troubleshooting our Hobart X18 dishwasher.
This is what I found in the manual...and on a couple of other sites....
Machine won't fill or won't fill high enough(LX18, LX30 display shows "E0," "E2," "E3," or "E4")
1.Low water pressure — check for clogged hose strainer; check that site water pressure meets minimum flow pressures.
2.Make sure probes are clean.
3.No water pressure — main water supply valves may not be working.
4.Drain
valve open - turn machine off to drain machine, then on. Repeat twice
(this assists in clearing any drain valve obstructions). Wait for
machine to reach READY mode and press WASH. Slowly open door several
seconds later and note water level. Close door; 30 seconds later, open
door slowly and check that water level is the same as it was. If not,
repeat the
OFF-ON procedure.
5. Delime machine.
If this doesn't help let me know and I will get to the bottom of it....good luck and thanks for rating my effort...The Fang.
