SOURCE: Lord of the rings: conquest for pc
That is an error with a specific Direct X file. If you did not install Direct X 9 with the game you should run the install again and this time let it do the install. If you still have the problem, then got to Start, then Run. In the Run box type dxdiag. This is a built in program that will check all of your Direct X files and fix any that are corrupted. If after running that program, you still receive the error, there may be a problem with the game. You will have to contact the software publisher to get support to help you.
SOURCE: Lord of the Rings: Conquest for PC error
Check your screen resolution. The optimum settings should be listed in your guide book.
Also, check the graphics settings required for the game compaired to the graphics card in your computer; you may need to upgrade.
Good luck and please rate my solution accordingly.
V/r,
Don
SOURCE: what is the registration code for lord of the
something that is in the packaging for paying csts
SOURCE: The Lord of the Rings Conquest for Xbox 360: I can't connect online and im pretty sure i made a...
you must have xbox live to along with the ea acount. if you do then some the the severs act funny.
