Please consult with a system admin/phone tech. They may have the password. If they do not have your password, the password will need to be reset. In order to reset your password, a system admin/phone tech will need to access your system manager within your voicemail system to change or remove your password.
The only "pins" you need to know is the pin for mailbox 999 and/or 998. From 999 you can reset or erase the password to every other mailbox. 998 is where you record the greetings. That assumes a Pana TVA voicemail system.
If that (voicemailnumber) is 500, I'd be looking for the lights on the TVA voice mail system to see if they are solid green. You could have lost the synchronization.
the general mailbox can be any mailbox from 100-998... or if you have 4 digit extension numbers, 1000-9998...or it can be one of a couple hundred other greetings if you are talking about custom service menus instead of a mailbox (all this is best determined by your local panasonic dealer/serviceman)
once you know which mailbox is your general mailbox: 1) call the voicemail 2) press "#6*" + the mailbox number 3) enter password then "#" 4) press options "3" then "1" then "1" 5) record your greeting then press "1" to stop the recording then "2" to save it 6) hang up
depending on programming restrictions: at ext 101 1) press "PROG" 2) "**" 3) the user programming password (most likely "1234") 4) "004" 5) "ENTER" 6) enter the extension number you wish to change 7) txt out the name (you must use the direction pad in the bottom right corner of your phone if you have 2 letters in a row that are on the same key) 8) press the "AUTO DIAL/STORE" button 9) lift hand set and hang up
Does your system use the FWD/DND option or is it the programming. I also need to know what kida system this is.
If it is for the TDA then you can (if you have access too) Prog soft key below LCD -> the press FWD/DND button -> Down on the silver button about 3 times. Should see 53:FWD N/A Time then enter Should see timer (sec) :xxx with your current time. Press new time example 015 for 15 sec then press enter.
If that doesnt work let me know and I get you the other way.
how to change password on PAnasonic KX-T7633
