Usually if a gas appliance (stove, water heater, etc) has a pilot light that either won't light, or stay lit, it needs a new thermocouple.
http://www.suremarine.com/images/stove-repair/safety-pilot2.jpg
Testimonial: "Where can I buy one. And are they universal size or do I need a model number for my Vulcan. Also can you please explain step by step how to change it. Gas scares me a bit. And not sure if I need to shut of gas to change thermocouple. Thank you for your help"
SOURCE: premier 30 inch gas stove oven does not light
do you hear any clicking when you try to start the oven portion of the range? if not lets try this, open the lower drawer so you can see the burner bar and mechanism for lighting the bake bar. as your watching the mechanism turn on the oven (nothing should happen as per your issue) while oven is on try lighting one of the top burners, any one will do wanna check if that lites the spark and in turn lites the oven pilot.if that does infact work you have a bad spark switch for the oven control
SOURCE: My oven gets too hot. flame doesn't shut down
The problem is the temperature probe has failed. This is inexpensive usually and easy to replace. This link should help
http://appliancehelponline.com/oventempprobe.html
SOURCE: I have the premier 24
More times than not the safety valve is the problem, you can read how to replace it and purchase the part by clicking on the link below,
http://www.appliancerepairlesson.com/
