Put power on the treadmill and it will incline until the motor stalls out without pushing any buttons. The belt never turns. Play with the switch a few times and the treadmill will go down until the motor stalls.
Do a Calibration on the treadmill. Take out the safety key. With 2 fingers, hold down the stop button and the speed up or spped plus button. keep holding them down as you insert the safety key, then let go of both.
Press the stop button 1 time, you should see all 0's in the windows, or EP 2P or something weird like that.
Press the Incline up button and then wait. If the incline go up until it stalls then down until it stalls the stops at the bottom, the you are recalibrated, take out the safery key and put it back in to see if all is well. If the incline takes off up again without touching a button, the you have wiring problems or control problems. Call service company to get it repaired.
an exercise ball was pulled under the belt and now the treadmill only stays on few a few seconds,but the incline and display work
i noticed everytime i use it the belt kind of stops on some places which is causing my leg to stop and nearly fell off from it a few times. any solutions?
My husband set up the treadmill and the incline is already up we want to put it down it don't work,you hear the click like is working, please need help.
When my treadmill is on an incline it squeaks. THe treadmill is new
Nautilus T912 treadmill
During operation I hit the incline button and the power goes off!
was working then slowed down then stopped. got off tried to run it without bein on it and belt did not go.
The incline lifted up by itself without the key inserted. Any ideas why this would happen?
