Hi My problem is that my Jamo Sub 200 sounds very weak even at max level. My amp is Pioneer VSX-519V-K and ps3 is my bluray player and are connected by HDMI. The sub used to sound great only at half level but now it sounds weak. We moved to another house and when i put my home theater back together the problem came up. Also the sub won't power up anymore when it's set to Auto mode from the back. Amps settings should be correct , speaker set up shows that sub is set to yes. Xover is set to 100 at the amp and from the back of the sub. Phase is set to 0. Sorry for my English :D I'am Finnish.
SOURCE: my jamo sub 200 & pioneer vsx517 receiver is not working properly
What do you mean that it sometimes doesn't work? It doesn't power on automatically?
Check settings of your receiver - if it has subwoofer output enables and if low frequencies from all channels are directed also to the SUB. By default only the LFE channel (.1) of 5.1 signal input is fed to the subwoofer. So Sub will work in this case only when you listen to 5.1 signal (DVD movie for example), but for radio or stereo music, only front speakers are used. By configuring this bass redirect, you can use subwoofer for all signal types.
SOURCE: Hi! I have purchased a
The TX has speaker setup and test tones for setting the balance and distance with test tones and proving the hardware works. If that all works the difference is probably external or settings.
What is different between the music source(s) audio and the HD movie source(s) audio? Ask yourself, how would a sub make high frequencies go missing? It can't.
Your other speakers are responsible for conveying the high frequencies.
