From what you stated ,,this could be a bad transmission or a shift sensor in the transmission ,,,this is a clutching problem with these automatics ..most cases have proven that you can change the transmissions fluid ,module and filter to allow proper shifting and the codes allow the clutching to return to normal...I am 90% sure from your post
SOURCE: Transmission seems to slipping....
Dear vdizon it seems your bearings are slipping inside your transmission.
This is usually caused by inproper use or stress to the transmission. Changing gears at high revs and double clutching may have caused the bearings to wear, or a service on the gearbox has not been performed by factory recomendation. I advise you to book your car into your mechanic to confirm the problem before the proble escalades.
I hope this has helped you.
SOURCE: won't go into gear to drive. may be transmission?
If the clutch has never been changed most likely it is that. The way you can check it is by removing the transmission and looking at the clutch disc. It could be transmission syncros but I am willing to bet you just need a new clutch.
SOURCE: 2002 Kia Sedona will go into reverse but will not
Whenever you find black transmission fluid in the transmission its time for it to be overhauled. im sorry to say but that is all you can do from here. When the friction discs burn up there is no way for the transmission to engage
SOURCE: Changed starter and now transmission won't engage in reverse. What happened?
is the level of fluid ok ? im afraid your transmission went bad not because of the starter change but it just happen at that time
SOURCE: 04 kia optima not shifting gears
Woiuld be just guessing,could be alot of things,,could be seriuos internal problem in transmission..best bet is take to mechanic and have checked.....good luck.
