Grundfos MQ3-45  1 HP Pressure Booster Pump  Logo
Jason Fox Posted on Oct 26, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Pump turns on and off constantly when in use. It didn't use to so this.
Stephen Pearson
Level 2:
  • Expert 49 Answers
  • Posted on Oct 26, 2013
Stephen  Pearson
Expert
Level 2:
Answers
49
Questions
Helped
23953
Points
136
Shut power off to pump drain system, if you have a tank with a valve stem on it (like your car tires) you need to check to see if the pressure is around 20 to 35 (or check the manufacture specifications on it), close all open lines and turn power back on. You can not compress water just the air, you were as they call waterlogged, and need and some air in tank.
I have an oilless 175psi craftsman, 1 hp. My regulator broke, and I replaced it with one from Homedepot for a husky, I believe. What happens is the pressure builds all the way sometimes, but mostly j
I have worked on compressors from 15 PSI all the way up to 5000 PSI and everyone of the regulators I have seen bleed the pressure of when you dial it down and you can hear it.
1helpful
I have a Rockford fosgate P4004 with two 12'
What is your question?
A thumbs up would be greatly appreciated if this answer is helpful to you. rockford-fosgate-p4004-two-12-peeu4x5nsxvd53n2rwetiqa4-3-0.jpg
Watchdog sump pump want stop beeping
if you have a home entertainment system just turn it on and up kidding the sump pump for our home is always running i have never heard in beep just whines constantly Is the pump still working? I have had pumps go bad before but they never beeped they didn't do anything after burning up the motor i wonder if its a battery maybe 9v
03 malibu quit while on hwy. Theft light on constant, tried to relearn keys no help. Removed air filter added fuel started and ran until it used up the fuel. Originally thought anti theft but now leaning...
You are correct twice. The antitheft is failing and turning off the fuel injectors. Go to this link for help. This is a classic GM problem and totally 100% related to the antitheft.
http://vatspasslockpasskeysecurityhelp.yolasite.com/
2000 FRONTIER DIES WHILE DRIVING IT WILL RUN WITH ON LIGHTS BUT IF TURN ON ANYTHING ELSE IT DIES
you may not believe me when i say this but your not pulling enough amps from your alternator mine did the same thing its in your belt sytem usually caused by a water pump being out of balance replaced my water pump and runs great! hope this helps P.S. my pump didn't seem to be bad it felt free and didn't feel like it had any wobble but apparently it did
When pumping gas the pump constantly disengages as if the tank were full - it doesn't matter which station or pump. It goes off about 10 times while filling the tank. I've taken it to the dealer...
Back pressure is going into the gas pump handle. If you havent already done so, when filling your car play around with putting the gas pump handle tube in at a different angle. My car often gives me the shits doing this too. I find that if I turn the handle so that it is at right angles or even completely upside down with the tube pointing in a different direction within the fuel intake on my car it works fine. Can be frustrating though particularly on high flow pumps.
1helpful
2answers
98 Ford Taurus SE needs water constantly, could
could be a leaking head gasket but the heater sounds like its air locked have the head gasket checked
2helpful
2answers
The fuel pump on my 1988 crown victoria runs constantly when the engine is running and pump is very noisy. When i turn the key on, the pump runs then stopps but runs constantly when engine is running. Why?
The fuel pump is supposed to run constantly when the engine is running. It is pumping fuel to the engine which is in constant need of fuel. It is starting when the ignition is turned on and then shuts down after a few seconds if you do not start the engine. This is exactly what it is supposed to do. You have no problem except for the pump being noisy. On a car that is 22 years old, I would suspect the fuel pump is failing and the noise you hear is it's death nil. Change the fuel filter and if the noise continues be prepared to have the pump replaced. It may fail suddenly or it may become hard to start. If you have never had it replaced just go ahead and do so, to prevent being stranded and a towing fee when it does fail.
Top Grundfos Garden Experts
john h
Jay Finke
Jay Finke
ADMIN Eric
ADMIN Eric
Are you a Grundfos Garden Expert? Answer questions, earn points and help others
