OK. very careful take a small drill bit, drill one hole on each side of the face holder the part the shows when the stereo is mounted drill juts enough to insert a pin or find a nail about half inch with the head so you can put it in when you close the latch (note.) the latch is hollow so you can drill about one 1/8 be very careful when you drill tape the tip of the drill bit so you don't drill more than what you need. It works I have my for a year good luck. motoroil
Locate the small plastic tab on the top of your Samsung phone, located in the groove between the faceplate the main phone body. This tab is very tiny, only about one-sixteenth of an inch wide.
Press on the plastic tab with your fingernail.
Continue holding down the plastic piece while sliding the faceplate off the top of the phone. The faceplate only slides off from the top, so don't try to force it in a different direction.
Release the plastic tab.
Line up the new faceplate with the top portion of your phone then slide it downward until it latches into place. You'll typically hear a soft click when the faceplate is secure. When properly placed, the new faceplate should not be able to wiggle or slide unless you press down the plastic tab once again
Read more: How to Change a Samsung Phone Faceplate ' eHow.com http://www.ehow.com/how_5146822_change-samsung-phone-faceplate.html#ixzz17o6dpgG0
for the broken latch xtremevision I had thesame problem broken latch
