I have a magnavox vhs player and recorder that has a tape stuck in it and also a tv with a vhs player built in with a tape stuck in it as well. Is there a way of repairing this without ruining the tape.
I had this problem when copying an old family vhs tape. I had to unscrew
the top of the magnavox to access the vhs tape. Then, I gently removed
the tape and replaced the cover. After winding the tape back, I put it
in the player and immediately pushed fast forward for about 3 seconds
before hitting play followed by d.dubbing. I was able to make a copy of
the tape and did not damage my original.
No,the DVD player build in tv can't record,only play DVD Disc only.Want to record personal VHS tapes only to DVD Discs,must have a seperate device unit VCR/DVD RECORDER device player not a device unit VCR/DVD PLAYER.Connected to the tv record VHS tapes to DVD Discs.
If you are trying to record a store bought vhs movie to dvd, there is a copy guard that is imprinted on the tape making it impossible to transfer the movie to disc effectively, on top that there probably a built in copy guard restriction in the machine making it even more difficult.
Magnavox ZV420MWB VCR/DVD Combo
The answer is YES YOU CAN! Take advantage of one-touch recording from videotapes to DVD+/-R and RW discs or from DVDs to VHS tapes. A variety of different inputs also let you record from compatible camcorders, external TV tuners or cable boxes.
CONSUMER ALERT: This model does not have a built-in tuner for recording TV programs and will not record copy-protected tapes or discs. For more information, call the Federal Communications Commission at 1-888-225-5322 (TTY: 1-888-835-5322) or visit the Commission's digital television website at: www.dtv.gov.
Depending on the procedure you may be pressing the record button instead of the D.Dubbing or Dubbing button. When recording from VHS to DVD you must first, load the blank DVD and VHS home movies, then play the VHS movies, then PAUSE the VHS movie when you want to START recording... then the only the you have to do is pressing the D.Dubbing button or the Dubbing button. If your VHS tapes starts to play after the Dubbing button is pressed you have been successful in Dubbing.
As long as the tapes do not have a copy gaurd on them they should record to the dvd. Home moves, tv shows that were recorded or unprotected tapes can also be dubbed.
unfortunately the machine is not a recording machine IE: it is a player only. However in todays day and age you can pick up a good used one at the goodwill for around 10-20 bucks that can record. hook up is easy, one cable in one out and presto you can record on a blank tape. just remember the begining of a blank tape always has a few seconds of nothing on it so dont hit rec just as you are watching it start the machine about ten seconds early.
hope this was helpfull.
I just got a MAGNAVOX ZC352MW8 also. I did get it to record the TV, but I can't get other DVD players to read the disk although the ZC352MW8 reads if fine. I have no idea what is going on with this machine.
Plug the DVD connections into the INPUT on the back of the VCR. This is sending the signal from the DVD player INTO the VCR.
If you are familiar with the VHS to VHS, then remove the VCR and replace it with the DVD player.
I hope this helps :)
If the question changes it will send me an automatic message. So if this was not enough info, just let me know! I'll actually hook mine up to record this way then I'll be able to tell you step by step if need be.
Even if you do get it connected you cannot copy from vhs to dvd as you have bought a vcr recorder with dvd player, not a dvd recorder.
You can only record to the vcr tape from a dvd, in the players controls.
