Question about York Fitness York 2 In 1 Cycle/Rower-Dual Features
Manual for York cycle rower mag - York Fitness York 2 In 1 Cycle/Rower-Dual Features
Recumbent cycle/rower rubber wheel under seat needs reablaced
What is the brand and model number of your cycle/rower?
Nov 14, 2017 | Exercise & Fitness
My york fitness r201 air rower wont retract
Did you get this fixed? Mine just broke too.
Mar 03, 2014 | York Exercise & Fitness
Reebok fusion rower manual-how to operate the electronic display
I have recently bought from a friend a reebok fusion treadmill. However due to a break up the treadmill was dismatled and put into storage and now they cannot remember where the wires go. Can anyone help?
Oct 15, 2011 | Reebok New York Giants Eli Manning Jersey
Reebok edge rower display console keeps reading 'stop'. only works if unplug adapter undereneath rower but only works for few seconds before returning to 'stop' ???
Welcome to FixYa.
If the console has a battery, most likely it is worn out already. You need to replace the battery. Some rower consoles does not easily expose the battery. You have to open it with screw drivers.
Thank you for using FixYa.
Sep 30, 2011 | Reebok New York Giants Eli Manning Jersey
I need a manual for a Proteus pmr 3000 rowing machine
Go to www.proteusfitness.com click on user's manual then click on proteus go to rower click on it you'll find your manual
May 15, 2010 | Exercise & Fitness
Is it still possible to get a Proteus PAR5000 instruction manual?
Go to www.proteusfitness.com click on to user manual then click on the Proteus box then to rowers and will have manual for unit.
May 15, 2010 | H2o Fitness Proteus PAR5500 Commercial...
Reebok I rower pulley wont move
Do you have the manual? If not, check here, they can get you virtually any Reebok manual.
Apr 25, 2009 | Reebok New York Giants Eli Manning Jersey
What kinds of boats are used for rowing?
The boats (or shells) are basically of two types and reflectthe two forms of rowing---sweep rowing and sculling. In sweep rowing each rower handles a single oar (about 12.5 ft or 3.9 m long) in sculling a rower uses two oars, or sculls, (each about 9.5 ft or 3 m long). The word shell is often used in reference to the boats used because the hull is only about 1/8" to 1/4" thick to make it as light as possible. These shells are also rather long and racing shells are as narrow as possible while recreational ones can be rather wide. Most shells today are made of composite materials such as carbon fiber, fiberglass, or kevlar. A few manufacturers still build wooden boats. Each rower has his back to the direction the shell is moving and power is generated using a blended sequence of the rower's legs, back and arms. The rower sits on a sliding seat with wheels on a track called the slide. Each oar is held in a U-shaped swivel (oarlock) mounted on a metal pin at the end of a rigger. The rigger is an assembly of tubes that is tightly bolted to the body of the shell.The exception to this are some european recreational boats called "inriggers" which have the oarlock attach directly on the gunwale. The subtypes of rowing shells are classified according to the number of rowers in the shell. Sweep Boats (each rower has one oar) These shells can have a coxswain---a person who steers the shell (using a rudder) and urges the rowers on. I have included in parenthesis the symbol used for each subtype along with some dimensions and weights. Coxed Pair (2+) Two sweep rowers with a coxswain. Coxless Pair (2-) Two sweep rowers without a coxswain. Coxed Four (4+) Four sweep rowers with a coxswain. Straight (or Coxless) Four (4-) Four sweep rowers without a coxswain. Steering is usually accomplished via a rudder that is attached to a cable that is connected to one of the rower's foot stretchers (this an adjustable bracket to which the rower's feet are secured). The coxless pair has a similar type of rudder setup. Eight (8+/8o) Eight sweep rowers with a coxswain. Eights are 60+ ft (~18.5 m) long and weigh about 250 pounds (~114 kg). Sculling Boats (each rower has two oars) Only in rare cases do these boats have a coxswain. Steering is generally accomplished by applying more power or pressure to the oar(s) on one side of the shell. The hands overlap (usually left over right in the US) during part of the rowing cycle, or are always left in front of right. Single (1X) One rower or sculler. Singles are about 26 ft (8 m) long and less than a foot (0.3 m) wide. Racing singles can weigh as little as 30 pounds (~13.5 kg). There are heavier (~45 to 50 pounds), shorter and wider versions often referred to as recreational singles. Double (2X) Two scullers. Most racing doubles can be also used as a pair with a different set of riggers designed for sweep oars. When used as a pair a rudder is usually added. There are also recreational versions of sculling doubles. Quadruple (4X) Four scullers. Often referred to as a `quad' and usually has a rudder attached to one of the sculler's foot stretchers as in the straight four. Most quads can also be rigged as a straight four using a different set of riggers. Octuple (8X) Eight scullers. This is rarely seen, though is used in the UK, at least, in junior competition where sweep rowing is not allowed. Weight Classifications There are basically two weight classes for rowers---heavyweight (HWT) and lightweight (LWT). Men (M) For team LWT boats, there is a 72.5 kg (~160 lbs) individual maximum, and the boat must average no more than 70 kg (~155 lbs). Women (W) The individual maximum for team LWT boats is 59 kg (~130 lbs), and the boat must average no more than 57 kg (~125 lbs). In the US, the women have an individual max only; no average. In some regattas in the US (usually head races late in the season) these limits are increased by 5 lbs. A rowing shell is usually built with a particular weight class of rower in mind. Until just recently the Olympics effectively had only HWT classifications.
Dec 01, 2008 | Sevylor Fish Ranger 280
York Fitness York 2 In 1 Cycle/Rower-Dual Features Logo
104 people viewed this question
Top York Fitness Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
Tom Chichester
ray gallant
ray gallant
Are you a York Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
