2006 Hyundai Sonata Logo
Posted on Apr 27, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2007 Hyundia Sonata Brake Lights
I have a 2007 Hyundia Sonata and the 3rd (upper center) brake light works, but the other brake lights don't. The bulbs and the brake fuse (stop fuse in box) look like they are OK. Any Suggestions
  • Anonymous May 11, 2010
    the left & right brake lamps are dual filament bulbs, remove both outer bulbs and check both filaments, and check for black fogging on the glass.
    i suggest replacing them regardless of what they look like, the filament can have an open in it, but still look ok.
    also, take a pedal depressor to hold the brake pedal down, then take a test light and check if the sockets are getting power.
    when you turn on your headlamps, to your taillamps come on?
Anonymous
Level 2:
Sniper:
  • Expert 83 Answers
  • Posted on Jun 28, 2009
Anonymous
Expert
Level 2:
Sniper:
Answers
83
Questions
0
Helped
89858
Points
379
There was recall for the 2006 and 2007 Hyundai Sonata Brake Light Switch assembly. www.promanuals.net
2008 Sonata. Which fuse is for the 3rd light?
Same as brake lights. Fuse 8. If your brake light and rear sidelights work, the bulb has burned out.
https://fuse-box.info/hyundai/hyundai-sonata-nf-2005-2009-fuses-and-relay
2answers
Why won't my replacement 3rd brake light work?
The 3rd brake light does not flash with the flashers. It works independently and only with the brake pedal. Have someone step down on the brake pedal while you check to see if the light comes on.
Brake lights fuses and brake light switch all replaced on my 2007 Hyundai Sonata There is no recall on my vehicle and brake lights still do not work What else should I do
Wiring.check any power to get to the brake lights,check connection,it might be open circult at the truck.get wire diagram to check step by step
Brake lights don't work but 3rd stopping light does
it should be easy, first check all the fuses, if that dont work remove the tail lights and check the wiring it may have broken wires or blown bulbs
2answers
Center brake light working but neither tail light brakes working both bulbs good
the center and brake light are not on the same circuit, check voltage coming from the switch
2answers
Rear break light will not go on but rear window break light will
could be the light itself,the red brake wire that comes off the rear brake lights that feeds this stop light,sometimes things get shoved against this wire and its cut,or if it splits off in the frame,it could also be broken here too
1helpful
2006 Sonata brake lights don't work except rear deck light.
Check the connection at the brake light switch for power comming out to the barke lights,try feeding power to the brake lights manualy using a jumper wire from your fuse box or battery,unplug the wire from the switch and put power to the harness if everything is OK the brake lights will work,then you need a new switch.
2helpful
Hyundai sonata brake lights
you will probably have to replace the bulb
How do I change to High brake stop light
It is either accessed through the trunk from underneath or the cover can be removed from the back of the light assembly and they can be replaced that way
Upper middle brake lite replacement 2006 hyundia sonata
ON MY HYUNDIA, IF YOU OPEN THE TRUNK AND LOOK UNDER THE LIGHT, YOU WILL SEE 2 NUTS THAT ARE RECESSED UP UNDER THE LIGHT. THAT MIGHT HELP.
Top Hyundai Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Hyundai Expert? Answer questions, earn points and help others
