Summit washers are prone to board failures i would say that is where the fault lies . thermafuse fuse means it has been overheating. means it can damage other parts. thermostat would thing that has just worn out thermostat can go if the unit overheats. under line is an electrical fault. but like i've said it is a common fault with this make and others. the main boards can only handle around 50c in temp after that they start to over heat and cause problems. the faults started when they moved the main board from the bottom to the middle.
