When I start the 7 inch netbook it says loading os image then a warning sign with unreadable message appears - it will not go beyond this screen
SOURCE: Have a new 7" Sylvania
Assuming that the restart was pushing the reset button on the back, then see my TIP at: http://www.fixya.com/support/r7350901-fix_synet07526_wifi_flashing
SOURCE: system will not boot. Keep getting the loading os
Flip it over on it's back and find a small hole 1in diagnally from the lower right corner. Put a tooth pick in the hole and press gently an hold for about ten seconds while connected to the AC power. It is looking for a password (WiFi Network Key) You have to double click on the little computer icon down in the right tool bar area, the one with the two side radiating arcs, and possibly has a small red X under it. The red X indicates that it is NOT connected. When you double click on that icon a window called RT28701 opens up, then you click on Wireless Information tab, then you cursor down to the name of your WiFi and high light it and click the connect box. Then another window opens up called Network Properties. Uncheck "The key is provided automatically" box. This will allow you to type in your "Network Key", the password that protects your network from outsiders. This "KEY" was set up when you installed the router on your server computer. If this does not work at first, turn the machine over on it's back and using a toothpick, insert it into the little hole about an inch diagonally from the right corner of the data plate, this will re-load a new copy of everything including the WiFi RT28701 driver. sometimes this driver gets confused. See my TIP at: http://www.fixya.com/support/r7350901-fix_synet07526_wifi_flashing Additional Information When I try to sign on with the red X showing, I get "The page cannot be displayed If I then double click on the icon down in the right corner I elucidated above, RT28701 opens up to "Internet Protocol (TCP/IP) with all zeros in the IP address field, and Subnet Mask, with no entries in the default gateway. That is a clue to me that the auto sign on has not found a viable network or needs something else. If I then click on Wireless Information tab, The list of available networks appear in the box. The machine keeps trying to associate my previous entered name site with my prefered site and tells me the signal is good, but it cannot link up. This is a signal to me that it has lost my Network Key or that the software has failed or both. I then click on advance and delete my prefered network and hit OK, this will force the software to ask me for my network again, and notice that the prefered is missing. I click on the name of my network again and then hit connect., then the Wireless Network properties window opens up and I can insert my Network Key again after I uncheck the "The key is provided automatically" box. I enter the key and hit the OK button. I still do not get a connection, so I reboot the machine, and wait for about 30 seconds and the machine synchs up because the little RED X under the icon has disappeared. Now the machine will hook to the internet as long as I want to, but sometimes when I turn the machine on it will not synch, so I go through the above sequence again. The secret is once you have entered your key and ask for the machine to synch up you have to reboot. Why? I do not exactly know, but I suspect that the WiFi driver looses it
For other information see below.
SOURCE: turn on power. and screen
Try the solution below.
if this is the SYNET07526:
Did you try the reset button on the back? about 1in. diagonally from the right lower corner of the data plate. insert a tooth pick in the little hole and hold for about ten seconds with the power plugged in. This should reset it to the factory specs.
If that does not work then you may have to flash the system. If you decide to do this, see my TIP at:
SOURCE: my 7' sylvania netbook wont
There is a reset button on the bottom of the laptop, To the right of the battery .
In the event your netbook cannot normally shut down or restart, press this button with a pin or straight paper clip to restart the netbook. If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: I have tried for
It has a problem finding your windows file to finish loading the CE image. If this is the SYNET07526, then follow the flashing TIP found at: http://www.fixya.com/support/r7350901-fix_synet07526_wifi_flashing
Be sure to follow the information exactly and insure the SD card that you use is put in the SD slot UPSIDE DOWN.
When you turn it on, as soon as the very first screen appears press F11.
Than it should take you straight to factory restore settings. P.S.
This will delete everything it so safe your stuff in Hard drives or flash drives.
hope this helps
Flip the machine over and find a small hole about 1in. diagonally from the right lower corner of the data plate. Insert the tip of a tooth pick into the hole and press down for about 10 second, with the AC power connected to the machine. It should re-load a fresh copy of the operating system
