SOURCE: I can't get my tablet unlocked(dot pattern) any ideas?!
On an android tablet there is generally a button combo, you can google your specific model for the answer. For instance, you might turn the tablet off and then hold the power button and the volume up or down button.
SOURCE: I need to reset my tablet to set a new pattern to
You'll need to do a factory reset:
1. With the device off, press and hold Volume Up and Power.
2. Release the Power button when you see the logo, but continue to hold Volume Up until the recovery screen appears.
3. Use the Volume buttons to navigate the menu and select wipe data / factory reset. Press Home to choose the selection.
4. Press Volume Up continue.
SOURCE: Model:v705-s tablet pattern lock.so unlock the
If you cannot unlock the tablet, look up the way to do a hard reset. You will lose all data, but it's one of your only options.
Usually the following method works:
1. Turn the tablet off.
2. Hold the volume down button.
3. Hold the power button.
This should boot you into your devices restore/update screen. If that combination does not work, volume up + power should.
4. Navigate to the wipe data/factory reset.
5. Wait for it to reload, and you're done.
I need help will sumone explain how to get in my tablet I am locked out with the gmail thing and I don't remember my username or password
