Question about LawMate PV-AC30 Camera In The Cord
Problem receiving video from pv-ac30 video recorder
Tried trouble shoot PV-AC30 remote controller as per your recommendation, still no light appear on the controller.
You can test the operation of the controller with the camera on your cell phone. Point the controller at your cell phone camera and see if the led in the controller flashes when you press any button on the controller. If it doesn't, check that the batteries are good and installed correctly. If you're sure it isn't a battery problem then the remote is dead
Jul 28, 2017 | Televison & Video
IR Blaster Code for DirecTV D12-300 Satellite Receiver
After digging around for awhile, the only onfo I could gather was that teh D12 uses the same codes as the D10 & D11, but could not get those codes, I am still looking around and will post any other info I may aquire. I would also suggest re-trying any codes for echostar. I can tell you this as I sell that equipment in my market and echostar provides the equipment and support for techs, installers, and retailers. Anyway Good Luck for now
Sep 26, 2007 | Panasonic PV-HS2000 Showstopper 30-Hours...
How to check whether the PV-AC30 remote control is working? Don't see any light when pressing power.
Use your camera on your cell phone to test it. Point the remote at the camera and see if there is a flashing light when you press any button on the remote. If you see one then the remote is OK, If not, then check the batteries and make sure they are installed in the right direction. If you're sure the battery is not the problem and you don't get a flashing light when you press any button, the remote is toast
LawMate PV-AC30 manual
To set the time / date stamp you'll need your remote control and you'll need to hook it to a TV with AV inputs. Be sure to correctly select the AV input the camera is plugged into. This is the most overlooked step that causes a lot of users frustration.
I've attached a YouTube video on how to accomplish the time/date setting.
Aug 28, 2012 | LawMate PV-AC30 Wall AC Adaptor DVR...
I am trying to use a Panasonic Showstopper DVR
It records on one channel only, not a tuner itself...........
May 24, 2010 | Panasonic PV-HS2000 Showstopper 30-Hours...
Panasonic Showstopper PV-HS2000
Yes, your hard drive has developed bad sectors. It will most likely need to be replaced. I am going through the same problem right now myself.
Feb 07, 2008 | Panasonic PV-HS2000 Showstopper 30-Hours...
How to Record From a TV Using PV-GS13?
connect a lead via your tv video out audio out jacks. Select tha appropriate channel (You may have to go through the av channel on you tv and tune in the channel you want to record) or, video or dvd player audio out video out jacks. connect other end to your camcorder. Select on the camcorder menu video in audio in. Turn on tv. If connected to video or dvd player, press play. Press record on your camera. When finished recording press stop. Presuming the camcorder is tape, you can buy a tape adaptor to play or record your mini tapes in a standard video recorder, then take them out of the adaptor and play them back on your camcorder. You can also do all this via a computer. Also if the camcorder is disk or hard drive it can be used the same way as a regular dvd recorder to record tv programmes once connected to you t.v. Let me know how you go 26 red
May 08, 2007 | Panasonic PV-GS31 Mini DV Digital...
Blue bars across video
I have the same problem with my PV-GS14. You have to find the last spot you recorded in, pause it, then switch to record, and just record something for a couple of seconds. Switch back to playback, and it should be fine. Neonlaundry, I read your other posts, and it seems we both have the same problems. If you find a solution, please post it. Thnks.
Mar 13, 2007 | Panasonic Palmcorder PV-GS12 Mini DV...
LawMate PV-AC30 Camera In The Cord Logo
37 people viewed this question
Top LawMate Video Cameras Experts
Marvin
Marvin
Are you a LawMate Video Camera Expert? Answer questions, earn points and help others
