Error Code the fault - with no tape the camcorder is ok but once tape is inserted it comes up with an error code which is EO1 and says below "Unit in Safeguard mode." "Remove then reattach battery." We removed battery and fault is still there when battery is re-attached we a clearing a fault by removing the tape.
the camera i'm using now also does the same thing, except I've tried this with two different batteries and the error still shows.the camera i'm using now also does the same thing, except I've tried this with two different batteries and the error still shows.
You can't post conmments that contain an email address.
1. The idler gear does not engage with the reel disk well.
2. Though the idler gear and reel disk are engaged with
each other, the tape is not wound because of overload
to the mechanism.
3. No FG pulse is output from the reel sensor.
4. No power is supplied to the reel sensor.
5. Tape transport operation takes place with a cassette
having no tape inside.
6. The tape slackens and no pulse is produced until the
slack is taken up and the tape comes into the normal
actually this error is related to s reel i.e, the supply reel of the camcorder and some time when we insert a new tape in camcorder it start giving the error because the amount of tension is more in new tapes as compared to the old ones (used one) . . try to use the old tape u would nt have any problem .
but with new tape u will have these kinds of problem some times , to solve this problem for new tape u need to take the camcorder to near by service center of sony .nd they will align the tape path of your camcorder .
E01 means Mechanism has not fully loaded up to the stop position
E06 meansTape drive motor is not rotating or stalled.
Thses two faults indicate a tape jam. please remove the cassette and insert a new cassette.
