Posted on Apr 27, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error code 6000
I tried to print something on my printer today...it said there was a paper jam... I throughly checked it out and there was no paper jam. It is now giving me error code 6000 and the Alarm light flashes. Any ideas on how to fix? I've tried turning off and back on as well as unplugging. same problem with my pixma mp198, no choice but to buy anther printer, so frustrating!!!!!
Anonymous
Level 2:
Scholar:
  • Expert 34 Answers
  • Posted on Apr 27, 2009
Anonymous
Expert
Level 2:
Scholar:
Answers
34
Questions
0
Helped
17007
Points
105
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
2answers
What is service code 6000?
Hello Richard Miller
The error that you have, it means that your printer has a paper jam, this is the error appears in you computer, may be in the printer have the next error number. P3 followed E3
If you are writing this review, it is because they believe you have a paper jam, if they have seen and removed yourself.
Principally printers and Canon, in many cases the system detects a paper jam, but is not exactly a paper is causing the problem, in many cases can be any object that has entered and is obstructing the passage of the pages.
My first recommendation is to look carefully where they enter the pages on your printer, if necessary use some lighting for better viewing, you might find something there.
If after all get nothing related, follow the steps below to solve your problem. http://www.en.rellenadodecartuchos.com/2015/04/delete-service-error-6000-or-p3-fallowed-e3-canon-pixma-mp240-printer.html
Even then, you can not solve the problem, I recommend the following way, which is to eliminate jam Canon inbox.
service-code-6000-xnnjabddbe1z3hwtjta3ekn0-4-2.jpg Remove error 6000 printer Canon PIXMA MG2410 en Rellenado
To be honest most of the time are other elements that influence paper jams, which can not be determined on the Canon printers.
2answers
My printer canon mx328 error 6000
Canon Printer Error Code 6000 is one of the typical errors that occur very frequently. It happens while users are attempting to print all of the printer's documents. The problem of Paper Jam is the main cause of this mistake.
Canon Printer Error Code 6000 refers to something in the printer that interferes with the movement of the carriage. In any case, I've been able to locate the problem: a piece of torn paper on the left side of the printer. Hard to get there However it's likely. The printer is running again! But often this is induced by a software error. Foreign objects, such as dust spores, pieces of paper, sticks, stickers, or other objects, block the proper opening of the paper feed tray. Due to the jam, the printer has an error of 6000.
Reasons for Canon printer error code 6000: The printer feed tray is wrongly fitted. A huge volume of documents next to the printer. The line feed is scratched or coated. Offer several print commands on paper at once. Faults in the sensor unit or in-line feed slit.
Our service: 24/7 support with the Printer expert team.
1helpful
2answers
Printer error has occurred 6000
Error 6000 gets displayed when there is a paper jam or other general malfunction. When the message "6000 Printer error has occurred. Turn off the printer then back on again. If the problem persists, see the manual." Is displayed, something may block the paper feed tray from opening.
If the printer is surrounded with documents or when you copy large documents such as books, make sure that you secure the clear space in front of the tray before printing / copying. When the error message above is displayed and if you find something is in front of the tray, remove it. Then, turn OFF the printer and back ON again and the printer will be ready for printing.
If you still have the trouble, contact the repair service.
Check the printer for any paper jam or try to reset the printer to release memory code errors.
1. Press and hold the Resume button for 1 - 2 minutes.
2. Open the cover.
3. Remove the cartridge and then reinstall it.
4. Close the cover.
5. Turn Off the printer.
6. Turn On the printer.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Printer Error message : Printer Error has occurred. 6000
2. Open the cover.
4. Close the cover.
8helpful
3answers
Error message 6000
6000 is a paper jam or jammed sensor.
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp600#ServiceAndSupport
Click service and support, then enter error 6000, then click Error LCD ... 6000..., then click Removing paper jams mp600. Sorry, but they use javascript so I can't give you a more direct link.
8helpful
5answers
2helpful
What is error 6000
I the paper is jammed. Purge unit is jammed with something and not being able to move. Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
5helpful
4answers
Canon mx310 error code 6000
Error 6000 is a service call error, meaning that the printer needs to be taken into a canon authorized service facility for repair.
This is a line feed error, with the problem originating from the timing **** disk film or the printer's logic board.
3helpful
4answers
I have a Canon MP 520 Pixma printer and getting error code 6000
There is got to be a paper Jam inside the printer OR
Look for something that might have stuck up the roller ..
Thanks
Fame !
3answers
Error code 6000 on canon pixma mp210 stops me from printing
Canon Printer Error Code 6000 is one of the typical errors that occur very frequently. It happens while users are attempting to print all of the printer's documents. The problem of Paper Jam is the main cause of this failure. There are several explanations why Canon Printer Error 6000 will happen when you work with a Canon printer. One of the factors is that one of the most simple common explanations is where the paper feed tray is blocked by certain dust particles and bits of paper. Another reason for this is that the paper feed tray is not adequately connected to the printer. If there is a tonne of a print order.
Reasons that cause Canon Printer Error Code 6000:
1. The feed tray of the printer is improperly fitted.
2. A large number of documents near the printer.
3. The line feed is scratched or smeared.
4. Giving multiple paper print commands at once.
5. Faults within the sensor unit or in-line feed slit.
Follow Blog: Canon printer error code 6000
Thanks for reading.
k24674
ADMIN Andrew
ADMIN Andrew
