Car Audio & Video Logo
Posted on Apr 27, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
CANNOT RESET CLOCK
Cannot re-set clock on Pioneer DEH-2850MP. Manual instruction to press AUDIO shows audio settings, does not bring up clock settings. CLOCK button shows only current time setting (which is incorrect and has been since first owned)
Anonymous
Level 2:
Champion:
  • Expert 201 Answers
  • Posted on Sep 08, 2009
Anonymous
Expert
Level 2:
Champion:
Answers
201
Questions
0
Helped
131563
Points
424
1) Press SOURCE and hold it until the unit turns off.
2) Press AUDIO and hold until clock appears in the display.
3) Press AUDIO again to display the setting u need to configure.
- when u found clock, press < or > to select the segment of the clock display you wish to set.
- press /\ or \/ to set the clock.
- press BAND or hold AUDIO when finish.
YBC (/\)
How to set clock on a pioneer car radio mosfet 50wx4
Mosfet 50wx4 indicates a feature of the Pioneer car radio. It isn't a model number. One Pioneer car radio/CD player with this feature is the DEH-1500. On this model, you need to turn off the unit to set the clock. Press and hold the Source button (to the left of the preset tuning buttons) until the device turns off. Press Audio (upper right corner) repeatedly until the clock appears in the display. Use the arrow keys (Skip/Back or Left/Right) on the right hand side of the radio to select a segment of the time to adjust. Use the Up/Down arrows to set the current time. Repeat choosing the time segment and adjusting the time until both the hour and minutes are correct. Press Band or press and hold the Audio button to exit the clock setting mode.
ManualsLib has the manual for the Pioneer DEH-1500 here: https://www.manualslib.com/products/Pioneer-Deh-1500-Car-Cd-Player-Mosfet-50wx4-Super-Tuner-3-Am-Fm-Radio-3432555.html . See page 16 for the clock setting procedure: https://www.manualslib.com/manual/129844/Pioneer-Deh-1500.html?page=16#manual . See page 6 for the picture of the front-panel buttons for the DEH-1500.
I hope this helps. Please add a comment with the model of the car radio if the above procedure doesn't work for your unit.
How do you set the clock on a Pioneer DEH-6 A/FM/CD player with no aux input jack? thanx
Real Answer to set Clock on Pioneer DEH-6 AM/FM/CD car player - DEH-6 will have no FUNCTION button.
1-Press SOURCE ("SRC" - button left of "1") and hold until unit powers off.
2-Press AUDIO ("A" - button upper right) and hold until clock appears in display.
3-Press </> arrows to select hour/minute to set - numbers will blink.
4-Press up/down arrows to increase/decrease hour/minute.
5-Press "BAND" or press "AUDIO" ("A") until unit powers off.
6-To check: Press CLOCK to turn on new clock setting display.
4helpful
How do i change the timee?
Hello there,
Instructions from the operating manual PDF found through Pioneer Electronics - Canadian site...
Setting the clock
Use these instructions to set the ctock.
1 Press SOURCE and hold until the unit turns off.
2 Press AUDIO and hold until clock appears in the display.
3 Press [LEFT ARROW] or [RIGHT ARROW] to select the segment of
Pressing [LEFT ARROW] or [RIGHT ARROW] will select one segment of the clock display:
Hour - Minute
As you select segments of the clock display the segment selected will blink.
4 Press [UP ARROW] or [DOWN ARROW] to set the clock.
Pressing [UP ARROW] will increase the selected hour or
minute. Pressing V will decrease the selected hour or minute.
¤ To cancel clock settings, press BAND.
¤ You can also cancel clock settings by holding down AUDIO until the unit turns off.
I hope that works for you.
4helpful
How do u set clock on deh p3000 pioneer
This was copied from the Pioneer support site:
Clock adjustment is performed in the "Initial Settings" menu. Please follow the instructions below to access time setting.
Press & Hold [OFF]
Pres & Hold [Muti-Control] until "Clock Set" Appears
Turn [Muti-Control] to choose setting
Press [Muti-Control] to enter setting
Time Setting:
Press [Muti-Control] to select time setting mode
Press [Muti-Control] to select time segment. Each press will select one segment of clock
Turn [Muti-Control], or click up/down to adjust time segments
Available functions:
Clock Set, Warn Tone, AUX 1, AUX 2, SW Control, Ever Scroll, BT Audio*, Pin Code Input*, BT Ver Info*
*Available only when bluetooth adaptor is connected
1helpful
How to set clock in pioneer deh4000ub
here is the link for your manual:
http://www.pioneer.co.uk/uk/support/manuals/DEH-4000UB/index.html
Setting the clock
This function is available only for DEH-4000UB.
Use these instructions to set the clock.
1 Use MULTI-CONTROL to select
CLOCK SET.
2 Press MULTI-CONTROL to display the
setting mode.
# Press BACK to return to the previous display.
3 Press MULTI-CONTROL to select the segment
Each time you press MULTI-CONTROL, one
segment of the clock display is selected.
Hour—Minute
As you select segments of the clock display,
the selected segment blinks.
4 Turn MULTI-CONTROL to put a clock
right.
# You can also perform the same operations by
pushing MULTI-CONTROL up or down.
Turning the off clock
display on or off
If the off clock display is turned on, the clock
appears on the display when the sources are
off.
OFF CLOCK.
2 Press MULTI-CONTROL to turn the off
clock display on.
# To turn the off clock display
Cheers!
9helpful
How do I set the clock on a Pioneer DEH 1700
1. Press SOURCE and hold until the unit turns off.
2. Press AUDIO and hold until clock appears in the display.
3. Press the arrows to select the segment of the clock display you wish to set.
4. Press + or - to set the clock.
5. To cancel clock settings, press BAND. You can also cancel clock settings by holding down AUDIO until the unit turns off.
3helpful
Can't set clock
1. Power the unit off (See instruction manual page 11, "Power ON/OFF") - Crucial missing instruction.
2. Use MULTI-CONTROL to select CLOCK SET. 3. Press MULTI_CONTROL to display the setting mode. 4. Press MULTI-CONTROL to select the segment of the clock display you wish to set. 5. Turn MULTI-CONTROL to put a clock right
17helpful
2answers
Pioneer DEH-P500UB set the clock
1 Press SRC and hold until the unit turns
off.
2 Press MULTI-CONTROL and hold until
CLOCK SET appears in the display.
3 Turn MULTI-CONTROL to select clock set.
CLOCK SET.
setting mode.
Hour—Minute
right.
15helpful
4answers
Clock
To set the clock on the Panasonic DEH-1600 car stereo, follow these instructions:
  1. Turn the radio off by pressing and holding the SRC button (under the label OFF).
  2. Press and hold the Audio button in the upper right corner of the radio. After holding the button for about 3 seconds, the clock will begin to blink (the hours).
  3. Use the up and down arrows to increase or decrease the time hours or minutes. Use the left and right buttons to toggle between setting the hours and/or minutes.
  4. When done, push and hold the Audio button again fir about 3 seconds until the clock stops blinking (hours or minutes).
1helpful
Pioneer DEH 1500
Here's a link to the manual at Pioneer's web site.
Here's how you set the time (from page 16 in the manual):
1: press SOURCE and hold until the unit turns off.
2: Press AUDIO repeatedly until the clock appears in the display
3: Press (left arrow) or (right arrow) to select the segment of the clock display you wish to set (hours, minutes)
4: Press (up arrow) or (down arrow) to set the clock.
- To cancel clock settings, press BAND
- to save clock settings press AUDIO until the display stops blinking
Top Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
