I have the above model dryer & all is working fine except it won't heat up to dry the clothes it just stays cold. How can I fix this?
SOURCE: we want to purchase a
go to sears .com click on parts out in your model number and they should have what you need,or go to repair clinic .com and do the same-mike
SOURCE: Clothes Dryer tripping house circuit breaker
If it is breaking the main circuit of the house there is something wrong. It should throw the breaker to the dryer only. It sounds like you are having a problem with a short between the main breaker and sub panel in the house. Is there any way you can move the breaker in the panel to a different place on the same panel to see if it is that circuit only. If not check the outlet and the plug on the dryer and make sure the wiring is connected correctly.
SOURCE: my dryer get to hot is simpson maxidry 505
sounds like it needs to be cleaned out,check outside to seeif the flapper is blowing open or if it is clogged with lint,if you have a leaf blower take vent line off of back of dryer and blow it out,vac inside of dryer and clean out the lint filter duct,if it's gas you should do this every year so you don't have a fire,electric every two years
SOURCE: I need a hindge for my Simpson Maxidry 361
You could Purchase it from :-
http://spares.alliedappliance.com.au/catalogue/catalogue_4_4_6_73_0ca48000.html
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
SOURCE: Simpson Maxidry Tumble dryer (Cloths dryer) How
Hi there, There is a switch at the bottom of the dryer. It has a groove for the spring to fit around. Then the spring goes through the metal tag with the holes in the pulley. The pulleys 2 prongs then fits into the slot near the motor. The belt goes through the pulley and around the motor wheel. When fitting the drum, tape the belt at three points on the drum with the machine door facing down making installation easier. Once installed remove the tape. The dryer now works like a dream. See the attached photo. Good Luck!
