I am after some hooks too. I am in Australia, and I believe Mum got the Mixer for a wedding present, about 40 yrs ago. Thanks :)I am after some hooks too. I am in Australia, and I believe Mum got the Mixer for a wedding present, about 40 yrs ago. Thanks :)
What area of the world are you in? I'll need to know so I can search for a local supplier for you.What area of the world are you in? I'll need to know so I can search for a local supplier for you.
You can't post conmments that contain an email address.
Try placing some "braces" rubber bands around the shafts of the beaters. This should tighten the hold of the shaft with the mixer and keep them more straight.
Hi Jill. Your mixer's gears are made of plastic and can't really handle heavy loads such as cookie and bread doughs. Contact Sunbeam Corp. to locate a parts place near you. You'll need to replace at least the large gear that turns the turntable base, possibly the worm gear that turns the large gear too. Grease these gears when you re-install the parts. You'll have to cut a couple of cable ties to get the machine apart enough to do the work. If this solution has assisted you, please rate it. Good luck! ricardok45.
