I want to format my phone memory
Actually I want to format my phone memory of Nokia 3110c as whenever i try to enter confriguation setting for GPRS it gives me errot target memory is full, Inspite there is nothing there in memory.
How to format nokia 3110c phone memory
Try giving restore factory settings ..
if problem persists then you have upgrade the firmware ...
you can upgrade firmware if you just have the normal data cable..
first you need to download the nokia software updater from the nokia site given below is the site:
http://europe.nokia.com/A4579163
after downloading just run the program and then it will guide you to upgrade the firmware
you need to have the internet connection and remember one more thing you must not remove the battery or turn off the phone or pc while the updation process is going on, if you do so it will permanently damage your cell phone ..
first backup all your data and then proceed to upgrade the firmware ..
Regards
-Dileep
Any further query you can get back to me
Dont forget to rate the solution
Whenever i open my music player it updates and then shows no music files found. my model is 3110c. plz help me. thanks in advance
*#7328748263373738# resets security code.
<span id="ctl00_ctl00_MainColumn_CenterColumn_ThreadSolutions1_Repeater1_ctl00_lblSolution">whenever i open my music player it updates and then shows no music files found. my model is 3110c.
Sir.
i forget secortycode of my cell phone.
plz solve my problem that how i can rest my problem.
Mobile =nokia
Model=2630
ime numbr=356997016627348
thanks
[email protected]
SOURCE: i want to format my phone memory of nokia 3110c
my phone memory card is asking password. But i dont know. how to remove password. please can you help me
SOURCE: how format nokia 3110c phone
You don't need to format just do this...
Firstly try to download this http://www.driversdown.com/drivers/Nokia-Phoenix-Service-Software_92760.shtml
Secondly download
3110c files
And install it in your PC..Disconnect all usb devices.
Now connect the phone with usb data cable without power on the phone to PC.Open Nokia pheonix...Click to "FILE" and select "open product" Choose 3110c rm237.Next Click to "Flashing" and then open "FPS-8C FLASH " after opening this just click to "Close" button and again click to "Flashing" select "FIRMWARE UPDATE" NOW you can select the firmware version as well as the product code at the top right whch is showing a small browse window.Remember if the product code of the particular is not there just select the highest one.
After loading ..Click to "Dead phone" and again press to "REFURBISH"
Wait until a message shows that "PRESS POWER BUTTON" Press it and wait until the phone automatically switch on.
Good luck.......
SOURCE: how to format phone memory of nokia 3500 handests tell me
Switch-off your phone.
1. Press and hold 3 keys; Green dial key, * Star key, no. 3 key on
keypad and then press the power on/off to swtich on the phone.
Remember, do not let go the 3 press and hold keys until you see a formatting word screen show!
2. After a few minutes when the Full phone formatting completed, your phone will back to original system and factory settting.
Thank you for using FixYa!
Do have a nice day and please remember to rate this solution.
Best regards,
SOURCE: My nokia 3110c cannot connect to service provider.
my nokia3110c is connected to my pc and i can also connect internet from my mobile to my pc by using nokia pcsuite in my system but my phone memory and numbers
What exactly do you mean "format"? Clear it?
