SOURCE: Bosch Axxis front loader will not drain
check filter. check no foreign objects fouling pump impellor - bra wires are the favourite
SOURCE: Bosch WFR2460 Leaks
are you sure it only happens in the spin cycle? and is the leak comming from the bottom front of the washer? most front laoders will leak due to a tear in the belows. that is the rubber boot that seals the washer tub to the front panel. if there was a hole or a tear in the bellows it should have a leak inthe wash cycle also. but there are also other possibilitys too.but its strange to only leak in a spin cycle due to the washer is extracting the water and not adding it. so check and see if it leaks in the wash cycle to and get back to me and we can go from there. looking through my training manual i dont see what could cause a leak in just the spin cycle
SOURCE: my bosch nexxt 500 series washer won't spin
possibly the motor brushes.
take back panel off. disconnect motor. remove bolts holding motor in and take out motor. check condition of brushes
SOURCE: Bosch NEXXT 500 SERIES washer Makes knocking sound while spinning
during transport there are fittings installed to prevent damage to the machine. The shaft may have got bent but before panic sets in try to check 1. that there is a gap between the mahine and units
2. that the unit is leveled.
SOURCE: washer fills and drains, but the drum does not run
Joe, Thanks for the prompt reply. OK, it sounds like one of two possible culprits, 1) the belt has broke or spun off. 2) the brushes in the motor are worn...although the initial symptom of this is typically manifest in "no spin" so I'd lean towards a broken or spun off belt. You'll need to remove the rear panel for a visual inspection to confirm or dismiss either possibilities. Let me know what you find out. If the belt is off check for possible reasons "why" ? It can be a loose drive pulley, ( the large one, not the motor pulley ) or simply an unbalanced load on the previous wash, just a heads up since you're looking around in there anyway. Of course the belt itself may be worn ( stretched ) or broke and thus at fault as well. Good luck, I'll watch your post. macmarkus :)
Thank You! I am ordering the valve and hope to get it fixed soon!
