SOURCE: Leak from maytag top load coin machine during spin drain cycle only
Possible that you would have a tub seal leak if it is only noticable during spin cycle. Possible that it "drips" slightly while in agitation, but not enough to notice it. While in spin mode you have a lot more parts moving as well as a lot more water pressure on the seal itself. Pump could also be leaking, but highly doubtful since it would leak a constant amount at all times. Good Luck!!! Jim
SOURCE: Whirlpool washing machine, top load
hi without further investigation its a bit hit or miss , does the whole tub tilt or is it just the inner drum ?
if its just the inner drum then it sounds like the bearings are on there way out
if its the whole tub then it could be one of the springs that it hangs from or the shock absorber underneath that may have come adrift
hope this helps
paul
SOURCE: washer makes loud knocking noise
HI thanks for your question. you could have something stuck in one of the holes, in the tub, or something caught in the pump, check those 2 . if need more assistance , get back to me. thanks the appliance doc
SOURCE: washer sounds like off balance during spin
old duets have nut on rear pulley that becomes loose. remove rear panel and tighten nut. check while spinning by hand if pop is felt. if it rotates smoothly then you may need new shocks on tub
SOURCE: Walking during the spin cycle
My GE front load washer model WCVH6800JBB have the same problem. I just purchased and installed it yesterday, 05/04/09. Just like everyone said... when it got to the spinning cycle it walked to the middle of my garage and all the connections in the back of the machine fell off. My husband checked the instruction... There are 4 nut bolts in the back of the machine near the rubber leg (level). You need to take them off and try to balance your machine again. My washer is running very smooth now. Good luck!
