The oven control board has shorted out and will need to be replaced. Here is that part to order.
There is also a video on that parts page to
show you how to make the repair.
SOURCE: Oven does not heat
I am having the same problem right before the holiday...can this be by myself or do I need a technician??
SOURCE: No power on right hand side burners
WHEN THE SURFACE SWITCHES ARE IN A ROW ON THE CONSOLE, THEY ARE USUALLY WIRED IN PARALLEL FOR THE INPUT VOLTAGES(RED AND BLACK WIRES ATTACHED TO EACH OTHER). IF THERE IS A BURN OUT OF ONE OF THE WIRES, IT WILL AFFECT THE OTHER SWITCH INPUTS DOWN THE LINE.
TAKE OFF THE BACK PANEL OF THE CONSOLE AFTER UNPLUGGING IT AND CHECK FOR VISIBLE SIGNS OF WIRES BURNT. REPAIR OR REPLACE IF NEEDED. SOMETIMES, THEY WILL DAMAGE THE TERMINAL OF THE SWITCH THEY ARE ATTACHED TO. IF THIS IS THE CASE, THE SWITCH WILL ALSO HAVE TO BE REPLACED.
SOURCE: Frigidaire Electric Range error code
Hi jacksmdmat,
Your f30 problem may be a bad sensor circuit. It may have an open connection or just plain defective sensor. Check the connection between the clock and the sensor as well as disconnect and measure the resistance of the sensor - should be about 1090ohms at room temp (75F)
SOURCE: How to lite a pilot lite on a frigidaire "Gallery" gas stove?
wet sparkers, let them dry out good
SOURCE: Frigidaire FGF316WGSF GAS range oven won't work.
check this out
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
