IBM NetVista PC Desktop Logo
E
ESLAM Posted on Oct 24, 2013
Motherboard BIOS
JerryClinton
Level 1:
New Friend:
  • Contributor 28 Answers
  • Posted on Oct 25, 2013
JerryClinton
Contributor
Level 1:
New Friend:
Answers
28
Questions
0
Helped
7411
Points
38
TOO general, this is literally a statement not a question! what about the motherboard BIOS? does it not work install a new BIOS the follows the brand of your motherboard. need to flash BIOS reset every thing to default? Pull battery pull CMOS jumper listed on motherboard. Power off PC Power On.
Just got a brand new gigabyte motherboard,when i shutdown the pc it wont reboot. when the power switch is pressed nothing happens no fans,led, nothing. the board is a ga-990fxa-ud3,cpu- amd phenomII...
Hi Orville,
Your problem is all about your motherboard you need to updated to BIOS firmware to solve your problem.
Go to the gigabyte website then go to your motherboard page and download and updated to the latest firmware for your bios.
Steps in flashing BIOS
How to Reflash Motherboard BIOS About updating BIOS... The whole BIOS updating procedure should be treated with extreme caution. If you do not encounter any system instability or bugs with the current BIOS version, we suggest that you keep it. If you determine to flash BIOS, you are taking a personal risk of BIOS flash failure. Please contact your supplier or our distributors/resellers for further remedy in case system crashes unfortunately because of BIOS flash failure. Before you begin... 1. Please make sure the BIOS version you want to flash matches your motherboard model. 2. If your BIOS is flash protected, please do not enable BIOS Flash Protection under Advanced CMOS Setup (AMI BIOS) or Advanced BIOS Features (AWARD BIOS) in BIOS menu. 3. Never interrupt when you BIOS is being updated. 4. Because BIOS flashing is potentially risky, if you do not encounter problems using the current version of BIOS, it is recommended that you not flash the BIOS. To flash the BIOS, do it with caution. Inadequate BIOS flashing may result in system malfunction. Three BIOS Flash Utilities... We provide three BIOS flash utilities at our website. Below are the overviews. 1 : flashbios_qflash.gif A BIOS flash utility embedded in Flash ROM. Not all motherboards have the Q-Flash, please use @BIOS or DOS flash utility to update BIOS if your motherboard does not have Q-Flash. Features-- With this utility, you only have to stay in the BIOS menu when you want to update BIOS. No need to enter DOS or O.S. mode. Caution-- Make sure you have a functional floppy disk with the correct BIOS version for your motherboard. UEFI - Download PDF User Guide pdf.gif Download PDF User Guide pdf.gif 2 : flashbios_atbios.gif A Windows-based BIOS live update utility. Features-- @BIOS helps you search for, download, and then update the latest BIOS in Windows operating system. Caution-- Make sure your O.S. environment is stable. UEFI - Download PDF User Guide pdf.gif Download PDF User Guide pdf.gif 3 : DOS Flash utility Features-- The flash utility is a combination of AMI and AWARD BIOS flash utility. You can use it with both AMI and AWARD BIOS. Caution-- Make sure you have a functional DOS boot disk with the correct BIOS version for your motherboard.
I hope my solution may help you.
Thanks for using Fixya...;-)
I want upgrade bios ga 8simlh rev 1.0,but can not
2helpful
I need bios or bios update installer.. motherboard
http://www.msi.com/product/mb/PM8M-V.html#?div=BIOS
2answers
My bios is corrupted how can i solve the problem
You can remove the battery to clear the BIOS - read the information from this link.
Although the link is about removing the password, the same things need to be done to reset BIOS to factory default.
My pc doesn't want to boot up. this happend after i updated my bios. what might be the priblem & what's the solution?
> this happened after I updated [the] BIOS
After the 'flashing', did you enter BIOS SETUP, and then use 'Load BIOS Defaults' ?
After that, did you use 'AUTO DETECT DISK DRIVES' ?
If so, were your disk-drive and your CD-drive detected properly?
Hopefully, you updated with the correct BIOS that is specific to exactly your motherboard.
Some motherboards have the capability to 'flash' the BIOS even when a recent BIOS-update did not fully complete -- check the manual that came with the motherboard for the exact key-sequence to activate this 'emergency' BIOS-update.
If you can remove the BIOS chip from the motherboard, and you have your own EEPROM 'writer', you can update the chip while it's mounted on this EEPROM 'writer', and then re-install the BIOS chip onto the motherboard.
How do I find which bios update to install - (find which motherboard) without opening the pc?
You just need to go to the BIOS page itself and look for the BIOS version. The version that you need relies on the BIOS chip and not on the Motherboard itself. As you know, Different motherboards may have the same BIOS. The BIOS version is usually located on the summary page either on top or at the bottom of the page.
2answers
Cannot open bios set up forgot bios password
Reset the motherboard BIOS. To do this:
1. Open your computer casing where the motherboard lies in.
2. Look for the BIOS jumper settings. It should be near the battery.
3. And there reset the bios settings. (To do this, refer to your motherboard manual.)
4. Once already done. Close the casing and power up your computer.
See how it works.:-)
2answers
I need a bios upgrade. I have a PT800DBP Motherboard Motherboard: CPU Type Intel Pentium 4A, 2833 MHz (7 x 405) Motherboard Name Unknown Motherboard Chipset VIA VT8763 Apollo PT800 System Memory 512 MB...
boot the pc from cold, note the long identifier number - it contains a 2 character identifier for the board manufacturer. For more info go to the Award bios website, it has a better explanation of this. From there you will be able to either download new BIOS from there, or the website of the vendor/manufacturer.
I want to update my motherboard bios. My motherboard bios model version is "Intel I945 BIOS for 945GM-S2 FA AWARD BIOS". What can i do now?
go to gigabyte website and select your motherboard no and then select download drivers in that normally an bios update is provided.
WARNING: updating wrong bios can damage your system.
do not interrupt in any case while updating your bios.
no power loss or any other cases.
be very careful.
Top IBM Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
