Volvo S60 03 2003 Logo
Mary Posted on Oct 24, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
It was recommended by a local mechanic to use Royal Purple, and so I have been using Royal Purple SAE 5W-30 with any oil filter on my 2003 Volvo S60 Turbo. It has 105,600 miles. Is this recommended for the type of the engine in my car?
Daniel Mc Entee
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Volvo Master 1,449 Answers
  • Posted on Dec 21, 2013
Daniel Mc Entee
Volvo Master
Level 3:
Renaissance:
Answers
1449
Questions
0
Helped
275583
Points
3556
If no oil leaks due to thin oil .then it will be ok. turbo like to burn oil .so should check the oil every day before driving.if you start to get a lot of ticking noise from your tappets then use a thicker oil.
1 Related Answer
clifford224
Clifford Beard
  • 1975 Answers
  • Posted on Oct 24, 2013
SOURCE: 2003 Volvo S60, 105,000 + mile service. What type
need to know the engine size as there is a 2.4 litler, 2.4 liter turbo, a 2.5 liter turbo and a 2.3 liter turbo.
Testimonial: "Hello, thank you for your reply - my 2003 Volvo S60 is a 2.4 liter turbo"
1helpful
LX. should I use 5w 30 or 10w 30 oil?
lost the operators guide? in the glove box.
katrina, what part of country,?
Key West or Alaska.? (the -4f rule is clear)
the opr. guide explains all that... by climate.
page 5-8 in fact does that.
ill post it now.
and the words.
"• SAE 5W-30
As shown in the viscosity chart, SAE
5W-30 is the only viscosity grade recommended
for your vehicle. However, if it's
going to be -4°F (-20°C) or above and
SAE 5W-30 is not available, you may use
SAE 10W-30.
These numbers on an oil container show
its viscosity, or thickness. Do not use
other viscosity oil such as SAE 10W-40
or SAE 20W-50 under any conditions."
25916713-lx3lfdsu0gl5simxdk0r4o1e-5-0.jpg buy the guide and not get stranded for simple things ?
3helpful
2answers
What type of oil grade should i use in my 2001 audi 2.8 a4 quattro..this car came with no owners manual,and its time to change..thanks
Engine oil capacity with oil filter replacement = 6.0 litres.
Oil grade for 2001 Audi A4 Quattro 2.8
1. SAE 5W-30 / 5W-40, VW 502.00 - all temperatures.
2. SAE 10W-30 / 10W-40, VW 502.00 - all temperatures.
3. SAE 5W-50, VW 501.01 - all temperatures.
4. SAE 10W-50 / 10W-60, VW 501.01 - all temperatures.
5. SAE 5W-30 / 5W-40, VW 501.01 - bellow +15 Celsius degrees.
6. SAE 10W-30 / 10W-40, VW 501.01 - bellow +15 Celsius degrees.
7. SAE 15W-40 / 15W-50, VW 501.01 - above -15 Celsius degrees.
8. SAE 20W-40 / 20W-50, VW 501.01 - above -15 Celsius degrees.
LONGLIFE engine oil:
1. SAE 5W-30, VW 504.00 - all temperatures.
2. SAE 0W-30, VW 503.00 - all temperatures.
Please do rate my response. Thanks!
1helpful
2answers
What is the Recommended oil weight for 1987 2.8 v6 fiero
1987 PONTIAC FIERO 2.8L 6-cyl Engine Code [9]
All TEMPS......5W-30 SAE 5W-30 is preferred.
CAPACITIES: Engine, without filter..........3.8 liters, Add extra oil when replacing filter. After
refill check oil level.
Oil Drain Plug.....15-20 ft/lbs
Thank you for using fixya and good luck
3answers
Can anybody tell me the correct type and weight of oil a 2004 volvo xc 90 uses also # for replacment oil filter
Oil filter is provided by year,make, model of your vehicle at the parts store. ---
Oil and fluids Oil quality
Engine oil must meet the minimum ILSAC specification GF-2, including ACEA A1, API SJ, SJ/CF and SJ/Energy Conserving.
Your Volvo has been certified to standards using ILSAC oil specification GF-2 5W-30. Volvo recommends use of oil with a quality rating equal to or higher than ILSAC GF-2. Equivalent and better oils include ACEA A1, API SJ, SJ/CF, and SJ/Energy conserving. Lower quality oils may not offer the same fuel economy, engine performance, or engine protection.
Volvo Cars recommends Castrol. Depending on your driving habits, premium or synthetic oils may provide superior fuel economy and engine protection. Consult your Volvo retailer for recommendations on premium or synthetic oils. Oil additives must not be used. NOTE: Synthetic oil is not used when the oil is changed at the normal maintenance is carried out. This oil is only used at customer request, at additional charge. Please consult your Volvo retailer. Operation in hot climates.
When temperatures exceed 86° F (30° C) in your area, Volvo recommends, for the protection of your engine, that you use a heavier weight oil, such as SAE 10W-30. See the viscosity chart below. pg129a.jpg Oil viscosity (stable ambient temperatures)
Operation in temperate climates
Incorrect viscosity oil can shorten engine life. Under normal use when temperatures do not exceed 86° F (30° C), SAE 5W-30 will provide good fuel economy and engine protection. See the viscosity chart above. Extreme engine operation
Synthetic oils meeting SAE 10W-30 and complying with oil quality requirements are recommended for driving in areas of sustained temperature extremes (hot or cold), when towing a trailer over long distances, and for prolonged driving in mountainous areas. Changing oil and oil filter
Oil and oil filter changes should be made at 7,500 mile (12,000 km) intervals. Volvo does not recommend the use of oil additives.
Synthetic oil is not used when the oil is changed at the normal maintenance intervals except at ower request and at additional charge. Please consult your Volvo retailer.
2helpful
2answers
What type of engine oil will need for my toyota
FULLY SENTETACHIC OIL ,VERY GOOD FOR ENGINE WITH ALOT OF MILES KMS UP
2helpful
Whats the oil capacity for a 2003 jeep liberty?
2003 JEEP LIBERTY 2.4L 4-cyl Engine Code [
Engine Oil Grade 1....API* SAE 5W-30 is preferred.
CAPACITIES:
Engine, with filter..........4.7 liters
2003 JEEP LIBERTY 3.7L 6-cyl Engine Code
Engine Oil Grade 1......API* SAE 5W-30 is preferred.
CAPACITIES:
Correct SYNTHETIC oil for 2007 CADDILAC ESCALADE
Royal Purple is compatible with fully synthetic oils so you can change over with no damage to your engine. You can go to the official site and they can give you all the options as far as what your looking for specifically.
2helpful
What oil do i use for my 2007 Cadillac escalade with 50k miles
Specs say:
If you start with synthetic, you have to stick with synthetic.
Just bought an '81 Vette with a rebuilt 350 with 5K miles on it. What weight and type motor oil is reccomended?
I personaly would run amsoil 5w-30 or royal purple 5w-30. Those are a full synthetic and I can tell you from experience they are great. I run Royal Purple in my silverado and Amsoil in my cbr 600rr. Also, from independant studies done on Royal Purple and Amsoil they can go longer between oil changes then most oils. Royal Purple has been tested after driving 22,500 miles and still could be used if you wanted to leave it in the engine. I usually change mine around every 10,000 to 12,000 miles.
2helpful
2answers
What motor oil is recommended for the 2003 SSR?
Look on the oil fill cap. Write down what it says then call around to find out who has this class of oil.You might even call the Chevy dealer and ask for the service manager, ask him .I like the Castrol Syntec 10w-30 for my 2001 Chevy Monte Carlo.
Top Volvo Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Volvo Car Audio and Video Expert? Answer questions, earn points and help others
