KLH KD1220 DVD Player Logo
Posted on Apr 27, 2009
Parental lock I have a klh 1220 dvd player im unable to watch any movies because everytime i try to play a movie it says to enter my password for parental control and i dont have a password . What can i do to solve this problem. Is there anyway to reset or parental lock code.
Anonymous
Level 1:
New Friend:
  • Contributor 5 Answers
  • Posted on Mar 03, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
5
Questions
0
Helped
1110
Points
12
The preset password is 3308. but first goto set up menu select rating press enter/play, select rating agin press enter/play, chose rating you want, then enter password 3308, press set-up to exit, press enter/play to start.
I find the user manual, for the DVD player ona18dp001, to be inadequate. What is the password for? Do I need it in order to play a DVD? What is the reason for the coxial jack? Thanks.
The password is used if the parental control is enabled. This lets a parent/guardian ensure that DVDs can't be watched without the password if the movie has a rating above the chosen limit. (If you obtained a used DVD player where previous owner chose to lock the system to Kid safe, you'd need the password to watch any movie that doesn't have that rating.) If the parental control is off, you do not need the password.
I can't find much on the ONA18DP001. In general, some older DVD players have an RF (coaxial) out cable connection for viewing the video on an older TV (NTSC tuner) with only an RF input. If your TV has other input options, you don't need to consider this input.
I hope this helps.
2helpful
2answers
I'm trying to play a dvd but it says that parental controls have been set. I know the passcode is 8888 but when I type that in on my remote (universal, not original) it doesn't even recognize that I've...
Sorry u have to buy an original remote for this.The universal remote,will not be response by the tv for tthis function.Try website like Remotes.com to buy an exact to the original remote.
2helpful
Need to reset code
Found this on another site, from personal experience but its very well written so here you go.
The Playstation 2 is not only a video game system, but also a DVD player as well. In many families, the Playstation 2 serves as the "kids" DVD player, which means that many parents choose to take advantage of the parental lock feature to limit what kinds of movies the Playstation 2 will play back.
There could be instances where you entered in a parental code months ago, and now can't remember it. Or, you may have purchased a used Playstation 2, and you never knew the code to begin with. If you or the prior owner set a parental lock code, the Playstation 2 won't play back many movies without entering the code first. You could try to hunt down the original owners, or start inputting every code possible starting with 0000, but it's easier to reset the password and disable parental lock using a secret code.
Here is the procedure to reset the parental lock code:
  1. Bring up a screen where the unit asks you to enter in the parental code. You can either insert a restricted disc, or enter the DVD setup menu and go to "parental control" under custom setup.
  2. When the screen asks for the code, press the SELECT button, then enter in the code "7444".
  3. The level adjustment under Parental Control dictates the strictness of the player. The lower the value, the more strict it will be. Either increase the value to lower the restriction, or disable the lock entirely by setting it to "off".
  4. Once you have made your adjustments, be sure that the DVD tray is empty, and press the RESET button on the front of the Playstation 2. It is imperative the tray is clear of any DVD or game for the unit to save your settings.
A note for parents: If you're wondering what is stopping your child from using the above procedure to circumvent your rules, you can verify that they haven't reset the parental control very easily. Since the above procedure eliminates the old password entirely, all you need to do is see if your original password still works. If it does, they did not use the above procedure to break the rules. If it doesn't, they might be trying to pull the wool over your eyes.
Please rate accordingly
Justin
28helpful
2answers
Player won't play certain dvd's
the password is the arrows you have to do forwrd,backward,forward,backward but use the doubke arrow keys. this should work i found the soloution the manual
Brand new audiologic dvd player, asking for password when you try and play a movie. Any idea what the default password is?
the default passcode for parental management is usually 0000, 9999, or 3308
the parental management system is there to prevent minors from watching unsuitable content.
4helpful
5answers
Parental screen coming up on a DVD. Not able to watch DVD.
use password 3308 to change the parental control to 7, and the movie will run
150helpful
14answers
PS2 PARENTAL CONTROL CODE
This is the only way to turn "off" parental control lock on the custom setup screen.
1) turn off ps2 with no dvd in drive.
2) turn on ps2 and insert dvd in drive.
3) when it asks about parental password, choose 'yes'.
4) when prompted for password, press 'select'.
5) the prompt will change and say 'delete password'. enter '7444'.
6) enter a new password (0000 works).
7) registration complete, dvd will start playing.
8) once the movie starts, press 'select'.
9) click the 'stop' icon.
10) click the 'stop' icon again (the icon must be gray even when you have it highlighted).
11) navigate to 'custom setup' ('select', setup icon, custom setup icon)
12) move to parental control option, press right directional button, enter password (0000).
13) move down to 'level'.
14) move up to desired level (off is at the top).
15) click 'x'.
16) go back to 'select' menu options, and press 'play'.
17) while movie is playing, eject disk and remove dvd.
18) turn ps2 off using switch on the back, keep off for five seconds.
19) turn on ps2, put dvd back in.
20) happy dance. ;)
3answers
I cant get the parental lock off of my dvd and it wont play any movies at all
Try this. The mintek dvd 2580 password " screen " looks like it wants four numbers, it actually wants five numbers. And they are 88888 as set by the manufacturer. Unless someone has changed it from its original password. If you ever need the code for the remote it should be 0717 . I hope this helps.
4helpful
5answers
How do you reset the parental control code?
Called Zenith.  They said: turn on the DVD player.  Hit "set-up". Scroll down to the "lock" icon.  Scroll over to "Rating". Scroll over to unlock.  Enter 0000.  Click on Ok.  Enter 0000 again, click Ok again.  Menu should read unlock.  Voila!
Input password screen
i believe that the problem is in the movie itself it has a password somewhere on the case try playing it on antoher dvd , c if it does it agian windman
Top KLH Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a KLH Televison and Video Expert? Answer questions, earn points and help others
