SOURCE: Steam blowing out of group head
Were you using cleancaf to descale? If so, it is not a strong enough descaler. Use Dezcal. or a Dezcal cleancaf mixture. The two work great together.
Make sure you get some descaler in the solenoid area by turning on and off the coffee button.
Hope it works out for you.
Espresso Parts and Cleaning Supplies
www.CeriniCoffee.com
SOURCE: brew group/dump box
If you open the door, start the machine, take a screwdriver in the hole lokated in the left lower side and a other in the hole lokated in the right top corner. Now should the machine do her selftest and go back to start positions.
SOURCE: Saeco Odea Giro - Clogged and coffee come out in water tray....
This has happened to our machine that we use for our youth group. We sent it in and they said it was clogged also. Not having a clue what they meant. It happened again and I figured it out. When you remove the brew group there is a hole just above it that dispenses into the brew group. Make sure it is not clogged. Give it a try Good Luck
SOURCE: no water coming through group head
Remove the shower screen and clean. If shower is clean then line to head is clogged.
SOURCE: water flowing in steam -but not for coffee -the pump works...
I am fairly certain you have a problem with your solenoid valve. See this post.
It's relatively easy to fix, and you might get lucky and "un-stick" your solenoid like I did. The hardest part is keeping track of which wires go where as you disconnect them. I strongly suggest taking pictures and/or labeling with a Sharpie. Otherwise, if you're just swapping out the solenoid, my guess is it will take you about an hour if you're being slow and taking pictures.
